O2 sensor spacer
Old Sep 21, 2005 | 11:03 PM
TypeR864's Avatar
Default O2 sensor spacer
My friend drives a 350Z and has a test pipe. In order to prevent a CEL he bought 2 spark plug spacers that are the same size as the threads on the o2 sensor. He then drilled out one of the spacers so that the o2 sensor would screw in all the way then screwed the second spacer onto the first and in turn into the exhaust essentially taking the o2 sensor out of the flow of the exhaust but still in the system itself. Would this work for R owners that have test pipes? Sorry if its confusing its really late.
Old Sep 22, 2005 | 08:04 AM
TSAngry's Avatar
Default Re: O2 sensor spacer (TypeR864)
it should work. my friend did the same on his scion tC. worked fine.
Old Sep 22, 2005 | 08:23 AM
JDM Factor's Avatar
Or just make a bung which Im doing and call it a day
b18cisbetter
Jun 15, 2008 11:05 PM
Pman92
Apr 18, 2007 06:46 AM
eLeCtRoNSi00
Mar 1, 2005 07:25 AM
SOHC_MShue
Jun 23, 2003 07:11 PM
