poor return of steering wheel
Old Sep 21, 2005 | 05:31 PM
Zeus Zore's Avatar
Default poor return of steering wheel
like 1/2 turn before center the wheel kinda stops.. car tuningen but will not self center
everything is changed last week (had the problem before this)
changed rack
busings
upper control arm lower balljoint / and tie rod ens (steering thingy)
and the alignment is DEAD on.... tryed a new pump.. and with out.. seemed the same (did how ever have a few problems with the "new" pump..)
so i changed everything.. and still it will not self center.. !?!?!
any GOOD iders ? or anyone tryed that there cars will not self center and what was the salution
thx
Old Sep 22, 2005 | 01:51 AM
Mista Bone's Avatar
D Tranny Guru
toe off or a bent LCA.
Usuaslly a bent LCA, which doesn't always show up on a alignment.
Old Sep 22, 2005 | 04:15 AM
Zeus Zore's Avatar
Default Re: (Mista Bone)
the toe is right on.. the alingment is 100% ok have had it done 3 times last times i was finish with rebuilding the suspention.. but yeah maybe the LCA !? but how !? and how will i know !?
Old Sep 22, 2005 | 05:34 PM
Zeus Zore's Avatar
Default Re: (Zeus Zore)
bummelum.... ..
Old Sep 22, 2005 | 06:43 PM
Dave421's Avatar
have the caster checked. It often has an impact on the amount of return-to-center
Old Sep 22, 2005 | 07:06 PM
Zeus Zore's Avatar
Default Re: (Dave421)
yes the caster was like about 0,20 minute on both sides.. (honda says 1.10 +- 1 degree) 60 minute = 1 degree
i have no selfcenter from like 1/2 turn.. and if i turn more and hit the gas.. it will keep the steering wheel there, instead like normal start turning fast towards center.
Old Sep 22, 2005 | 08:31 PM
R-Lug's Avatar
If your steering wheel has been removed, then perhaps it was re-intalled "off center"
Old Sep 23, 2005 | 02:30 AM
Zeus Zore's Avatar
Default Re: (SeaLevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaLevel &raquo;</TD></TR><TR><TD CLASS="quote">If your steering wheel has been removed, then perhaps it was re-intalled "off center"</TD></TR></TABLE>
nop.. when driving straigt it is in the middel.. but i dont go 2 the center after a turn !...
Old Sep 23, 2005 | 02:37 AM
q.'s Avatar
q.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeus Zore &raquo;</TD></TR><TR><TD CLASS="quote">
nop.. when driving straigt it is in the middel.. but i dont go 2 the center after a turn !...</TD></TR></TABLE>
I forget name of part, my old EG had this problem too..
Old Sep 23, 2005 | 02:39 AM
Zeus Zore's Avatar
Default Re: (q.)
then plz do remember and tell me what you did !!!
Old Sep 28, 2005 | 07:36 PM
Zeus Zore's Avatar
anyone ?
Old Sep 28, 2005 | 09:01 PM
fastrunner's Avatar
Default Re: poor return of steering wheel (Zeus Zore)
check the cable reel that is under your stering wheel, if its broken it might be stopping the wheel from returning.
Old Sep 29, 2005 | 04:30 AM
Zeus Zore's Avatar
Default Re: poor return of steering wheel (fastrunner)
not that either...
crazyhorse2011
43
Dec 18, 2017 05:27 AM
Jer'rome
Mar 4, 2013 02:57 PM
jmai86
Suspension & Brakes
Jun 2, 2012 08:49 AM
swizz977
19
Jan 29, 2012 05:24 AM
ScottF
Mar 29, 2010 11:02 AM
