Question About Tapping
Old Sep 21, 2005 | 01:05 PM
litterbox's Avatar
I am a (Trial User) Army
Default Question About Tapping
Hey,
Ok, so this pic below is the broken piece of the inside of my tranny casing. What is supposed to thread in there is the pivot ball for the clutch fork.
Right now the tranny is at a welder and he's using filler to make a mound. I am going to have to drill and tap it.
My question is: with my regular tap set, I have the thing with the two handles that you twist which turns the tap bolt thing. I can't use this becuase of the tight space, the long handle arms will not clear the tranny casing walls.
So I need something long to attach the tap rod thing to. What should I use. I'm NOT going to use a drill because I need something that I can turn with my hands slowly.
Any ideas?
Old Sep 21, 2005 | 01:25 PM
B18EG6's Avatar
Default Re: Question About Tapping (litterbox)
what size hole are you tapping it with?
For the tap, the top of it is square right? Does the size happen to fit into a standard 3/8 or 1/2" driver?
Old Sep 21, 2005 | 01:27 PM
hulkhb's Avatar
Default Re: Question About Tapping (B18EG6)
Go to your local tool supplier and get a long shank tap, they range from about 5-8"
Old Sep 21, 2005 | 01:34 PM
2old_honda's Avatar
find a socket that fits the end of the tap, then use an extention and rachet.
Old Sep 21, 2005 | 03:09 PM
blueoval557's Avatar
Default Re: Question About Tapping (2old_honda)
DO NOT USE A RATCHET. When tapping, you need pressure on both sides of the tap while turning. Using a ratchet only puts pressure on one side of the tap, and you WILL NOT get a straight tapped hole. It will be all wobbly, especially since its aluminum. I know from prior experience.
Id would say use the long shank tap as mentioned before, if you are stuck on not using a drill. I personally would use a drill just because you will get a much more precise thread over doing it by hand, but thats your choice.
GOOD LUCK!
Kyle
Old Sep 21, 2005 | 03:16 PM
litterbox's Avatar
Default Re: Question About Tapping (blueoval557)
Hey guys,
Thanks for all your responses.
I'm tapping with a 1/2x20. Yeah, the top part is like a square top.
I'll try and find a shank tap.
I don't want to use my drill because I can't vary the speed of it. I tried using the drill on some other tap and I completely fucked up cause the rpm speed was just too fast for me to control the angle.
I got the tranny back from the welder. Pics up in an hour after I go after a shank.
Old Sep 21, 2005 | 03:24 PM
litterbox's Avatar
One more thing: When I drill my hole, do I go one size under the tap? Like, I'm tapping with a 1/2x20, so I drill with a 3/8 bit?
Old Sep 21, 2005 | 04:36 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">One more thing: When I drill my hole, do I go one size under the tap? Like, I'm tapping with a 1/2x20, so I drill with a 3/8 bit?</TD></TR></TABLE>
no offence.. but these questions tell me that you probably shouldn't be doing this yourself. i suggest you ask someone to show you how to do this first..
http://www.engineersedge.com/tap_drill_chart.htm
^^ this is the tap/drill chart that i usually use.
You are going to need a "bottoming tap"...
Good luck.
Old Sep 21, 2005 | 04:43 PM
litterbox's Avatar
Default Re: Question About Tapping (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck.</TD></TR></TABLE>None taken. Thank you for that. I am doing this myself. I've done everything myself up until now. That includes teaching myself how to weld, fabbing up my exhaust, doing my first swap in my garage (k24a2 into EG), clutch install, etc etc. I just dont' have alot of experience...gimmie a break.
Old Sep 21, 2005 | 04:51 PM
Engloid's Avatar
OG Fabricator
NO!!!! Definitely not!!! You need to reference a drill/tap chart to find out what size to drill it.
This chart in the link below says that for a 1/2-13 bolt, you drill the hole to 27/64 (.4219").
http://www.americanfastener.co...l.htm
Old Sep 21, 2005 | 04:56 PM
litterbox's Avatar
Default Re: Question About Tapping (Engloid)
Yeah, I saw the one that 2point2 posted, thanks.
1/2-20 .4531 29/64
Old Sep 22, 2005 | 03:54 AM
Timmah!!'s Avatar
Thoes are getting printed out and taped to the wall in my shop!
Old Sep 22, 2005 | 06:03 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">None taken. Thank you for that. I am doing this myself. </TD></TR></TABLE>
lol.. you are just as stubborn as me!
Old Sep 22, 2005 | 06:11 AM
litterbox's Avatar
rofl
caspersrevenge1
Jan 29, 2014 04:36 AM
ivan93egreppin210
Apr 9, 2008 08:12 AM
litterbox
18
Sep 21, 2005 05:54 PM
gocivicgo
13
Jun 26, 2003 05:36 AM
preluder
Jun 20, 2003 03:53 AM
