Suspension is fucked up!!!!!
Old Feb 28, 2002 | 09:55 PM
94cxhybrid-T's Avatar
New User
Default Suspension is fucked up!!!!!
I hit a 6" pot hole this evening and when i got home i popped my hood and noticed that the shock(Kyb AGX with ground control coilovers) was pressed completely out of the rubber grommit. This is in a 94 civic Hatch. I have no idea what to do. I looked up the diagram for the front shock on hondaautomotiveparts.com and it looks like the rubber grommit(#7 in the diagram) is in two pieces. I dont understsand how the shock would be supported if it was supposed to be two pieces. The only thing i can think of is that when the shocks were installed one of the round plates(#9) most likely the one on the dust cover was not put back on. But that doesnt make sense looking at the diagram. heres a link to the pic:
http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
If any one has any idea what i need to do to fix this that would be great.
Old Feb 28, 2002 | 10:33 PM
tonyxcom's Avatar
Default Re: Suspension is fucked up!!!!! (92 si B18C)
The lower washer probably got pushed past the oversized part of the shaft. Hopefully all you will have to replace is the washer, which probably got a little elongated, and you may have to dremel it off
Old Mar 1, 2002 | 06:07 AM
lsvtecracer's Avatar
Default Re: Suspension is fucked up!!!!! (tonyxcom)
Well, i have the same setup you have, but on a 1992 Integra...I hit a pothole and the same thing happen..It turn out one of washer busted broke apart due to the impact of the pothole so I took the sturt out and just replace the washer and everything is fine...
Old Mar 1, 2002 | 07:43 AM
New User
Default Re: Suspension is fucked up!!!!! (lsvtecracer)
thanks i am going to the river this weekend and leaving my car in a friends garage. I will take it apart on monday and do the reapir. Thanks alot aas it looks now everything is ok. Guess i need a washer. Thanks a lot for the replies.
VWscooby
Jul 11, 2010 06:45 PM
civics4lyfe
Suspension & Brakes
Jan 30, 2009 03:39 PM
crxsiperf
13
Jan 15, 2005 06:09 PM
Gennady
Sep 25, 2002 03:49 PM
