96 civic EX with b16a2 and a jumper harness to run a p2t ecu. Would it interfere with getting REF?
Old Sep 21, 2005 | 12:13 PM
SiB16A's Avatar
Default 96 civic EX with b16a2 and a jumper harness to run a p2t ecu. Would it interfere with getting REF?
i am going to get a jumper harness, but would that interfere with getting it bar'd?
Old Sep 21, 2005 | 12:17 PM
UNKNOWN_MEMBER's Avatar
Default Re: 96 civic EX with b16a2 and a jumper harness to run a p2t ecu. Would it interfere with getting R
Just try to make things look clean. Oh and they check for EVERYTHING. Good luck man.
Old Sep 21, 2005 | 12:21 PM
SiB16A's Avatar
Anyone elses opinions? By the way thanks.
Old Sep 21, 2005 | 03:06 PM
SiB16A's Avatar
help !
Old Sep 21, 2005 | 04:58 PM
SiB16A's Avatar
somebody has to know something!
Old Sep 22, 2005 | 03:41 PM
SiB16A's Avatar
ttt, also do i need a 99 si cat? can i use my stock 96 ex cat?
Old Sep 22, 2005 | 03:50 PM
jayswift's Avatar
you can't run any jumpers when your getting BAR'd. you'd have to convert your wiring to OBD2 ver.B (ie. dash and engine harness). you should call your nearest ref station to confirm but i'm pretty sure they'll tell you the same thing. and as long as your cat has both primary and secondary O2 sensors fully functional, then it won't matter if its an ex or si.
Old Sep 22, 2005 | 03:59 PM
SiB16A's Avatar
damn i just ordered a harness for nothing.
Old Sep 22, 2005 | 09:44 PM
Stripped Honda's Avatar
99-0104
if you have the converson harness just install it and try to pass it ... sometimes they want you to change your canister to the 99-00 si canister the cat shoud be fine good luck
Old Sep 22, 2005 | 10:41 PM
SiB16A's Avatar
yeah i found out the ex/si cat is basically the same. Has the same product number
Old Sep 22, 2005 | 11:00 PM
dantastic's Avatar
you'll NEED to run the obd2b ecu. i dont see why the jumper harness will cause you to fail inspection. as long as the obd2 scanner port still works, it shoulndt matter. the only thing you have to worry about is the fuel tank pressure sensor. i think there's a fix for that now....
Old Sep 23, 2005 | 11:46 AM
SiB16A's Avatar
Default Re: (dantastic)
i was told by "ongking" that only the 96-97 hatchback didnt have the gas sensor? if i dont have it what is the fix for it?
Azxster
Sep 6, 2007 03:25 PM
killacam661
Jul 22, 2007 02:24 PM
clean-jdm-ek
May 31, 2006 08:43 PM
EK9Greg
Aug 21, 2004 08:32 PM
