distributor timing help
ok.. i've been having alot of heistation right after i start the car... so i decided to check my timing.. rt now when i use the timing light on the flywheel it looks like this. (car is fully warm 750 rpm and service connector is jumped)
15 }
bracket is the mark on the block...
is this the correct timing?? should i be using stock specs for a boosted car??
thanks
15 }
thanks
Well, you should get the timing tuned for your engine. You could gain/loose power at different rpm ranges depending on your setup and timing.
Are your timing marks ok for TDC on the flywheel and cam gears??
