blow off valve location???
Old Sep 20, 2005 | 09:02 PM
11SEC CIV's Avatar
Default blow off valve location???
Does the location of the BOV matter? Cold side to hot side?
any info will be appreciated!!
Old Sep 20, 2005 | 09:14 PM
1turbodc2's Avatar
it needs to be on the charge pipe i don't know it that helps at all
Old Sep 20, 2005 | 09:31 PM
extrmeboost's Avatar
Default Re: (gssr)
there has been a lot of debate on this subject, however no matter what it needs to be at least 12" from the throttle body. It is debatable but a lot of people(all the people who matter) would say on the hot side of the intercooler is the best place for the bov, meaning ON the intercooler.
Old Sep 20, 2005 | 11:43 PM
onefstek's Avatar
I have mine on the hot side. I figured that if I have to blow off some air, it would have to be hot air instead of cold air.
But again, thats just me. I don't know if it helps or not.
Old Sep 20, 2005 | 11:56 PM
Default Re: (onefstek)
thats one good reason to have a bov on the hot side, but its supposed to be the best place to prevent compressor surge(air going against the turbo)
Old Sep 21, 2005 | 03:07 AM
BoOstedEM1's Avatar
Default Re: (extrmeboost)
Ive seen 800+hp supras with blow off right out the ic cold side and doing just fine. Yet thats not where im going to put mine its just the fact people put where there opinions are at.
Old Sep 21, 2005 | 11:39 AM
11SEC CIV's Avatar
Default Re: (BoOstedEM1)
bump for so more input
Old Sep 26, 2005 | 02:55 PM
tthame1's Avatar
Default Re: (12SEC CIV)
I seriously doubt it matters. There are just as many people making great numbers and having good reliablity with it on the cold side as there are with the hot side. As far as someone opting to blow off hot air instead, it really wont matter since its all passing through the intercooler anyway.
Old Sep 26, 2005 | 03:05 PM
97turbols's Avatar
Default Re: blow off valve location??? (12SEC CIV)
I think it is probably more efficient near the turbo on the hot side, but you can put it on the cold side and be just fine. Mine is going on the cold side, but if I wasn’t running a/c I would run a backdoor w/ it on the hot side.
Old Sep 26, 2005 | 04:46 PM
TurboCoop's Avatar
Default Re: blow off valve location??? (97turbols)
If youre running enough boost you could have one on each side of the IC. Ive seen some high boost Supras with it. I have mine on the cold side, about 12" from the TB.
Old Sep 27, 2005 | 05:55 PM
dunkd's Avatar
hmm how about 2 bovs? one on each side
Old Sep 28, 2005 | 10:19 AM
yee SERIOUS's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">hmm how about 2 bovs? one on each side </TD></TR></TABLE>
that's what it says on the post above yours!
Silvertc
Dec 31, 2009 12:41 PM
showtymers619
Apr 18, 2004 09:17 AM
PetroGuyX
May 2, 2003 07:35 PM
BoostedsiR
Apr 19, 2003 03:30 PM
ion_four
Jun 14, 2002 04:25 AM
