Is it safe to run 94 octane with 12.1:1 compression?
Old Sep 20, 2005 | 02:17 PM
VSBB6's Avatar
Default Is it safe to run 94 octane with 12.1:1 compression?
Im doing my H22 buildup with Type S pistions, 0.02 mill, thin head gasket and flat valves, which I calculated would bring compression to approx 12.1:1.
The highest octane pump gas that we have is 94, should I hold back to lower compression just to be safe?
Old Sep 20, 2005 | 03:04 PM
msmotorsports's Avatar
Default Re: Is it safe to run 94 octane with 12.1:1 compression? (VSBB6)
94 octane will be fine for normal driving. Just tune on the conservative side (Slightly rich with non agressive timing).
Old Sep 20, 2005 | 03:08 PM
RudeBwaiSi's Avatar
I think with a good tune, you'll be safe.
Old Sep 20, 2005 | 03:13 PM
flyrod's Avatar
Default Re: (RudeBwaiSi)
Tune it and you should be fine.
Old Sep 20, 2005 | 03:33 PM
itralex's Avatar
Default Re: (flyrod)
Hey, I'm local to you and my Compression ratio is 12.6:1
I run 94 all day long and its ok, just don't rag on it if you're running straight up 94, a lil race gas always help
Old Sep 20, 2005 | 08:15 PM
allm0torGSR's Avatar
Default Re: (itralex)
I have 12:1 and I use 93, no problem. It's all in the tuning. You'll be fine on 93 octane, the AEM EMS is capable of the level of tuning needed to pull it off. I have an Uberdata tuning system myself.
Old Sep 21, 2005 | 07:15 AM
powerline's Avatar
Default Re: (Yankees=Choke)
12.6-1 on pump 93 and it's fine, little race gas once in a while, just get it tuned..
407-707 POWERLINE
Old Sep 21, 2005 | 09:03 AM
thedread's Avatar
I'm doing a similar build to yours with Jun cams and valvetrain, but with 91 octane gas. A number of people in SC are running higher than 12:1 compression on 91 octane pump gas. So you should be fine...for that matter me too!
Old Sep 21, 2005 | 09:08 AM
PirateMcFred's Avatar
I am running 12.25:1 on 91 oct. I am at 5000' elevation though...
Pirate
Old Sep 21, 2005 | 10:00 AM
PocketRockets Racing's Avatar
from 2300-3500 R's, part throttle, which is all that is really done at these R's, seems to be the most difficult to deal with the H22
Old Sep 21, 2005 | 10:25 AM
2k.civic.si's Avatar
Default Re: Is it safe to run 94 octane with 12.1:1 compression? (PocketRockets Racing)
more then fine...i run 12.7:1 on chevron 91....
FastFoot
May 19, 2014 08:42 AM
^AnDre^
Apr 6, 2005 09:21 AM
donnjuan2point2
Jul 5, 2003 03:19 PM
powerfulperformance
Jan 24, 2003 08:08 AM
Nebula
Nov 4, 2002 03:49 PM
