starting issues
Old Sep 20, 2005 | 01:01 PM
sheBangZ's Avatar
Default starting issues
how's its going. I got a bit of issue here and hope you guys can help me out.and yes i tryed searching but I want to hear it from guys that been through this before. ok, so every once in a while I'll only hear the engine click once when i'm trying to crank it. After a couple times it'll crank, I kind of figured it was the starter.. But now it seems to be struggling to crank also, it'll turn over but it turns over slow........ and then starts. Is this just the starter or could i be facing a larger problem?
Old Sep 20, 2005 | 01:10 PM
xteg95's Avatar
Default Re: starting issues (sheBangZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ &raquo;</TD></TR><TR><TD CLASS="quote">how's its going. I got a bit of issue here and hope you guys can help me out.and yes i tryed searching but I want to hear it from guys that been through this before. ok, so every once in a while I'll only hear the engine click once when i'm trying to crank it. After a couple times it'll crank, I kind of figured it was the starter.. But now it seems to be struggling to crank also, it'll turn over but it turns over slow........ and then starts. Is this just the starter or could i be facing a larger problem?</TD></TR></TABLE>
sounds more like the battery or alternator.
if its the starter it should either click or start.
Old Sep 20, 2005 | 01:14 PM
sheBangZ's Avatar
What about the clicking I get I first try to start it? So I'm facing battery and starter.
Old Sep 20, 2005 | 01:25 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ &raquo;</TD></TR><TR><TD CLASS="quote">What about the clicking I get I first try to start it? So I'm facing battery and starter.</TD></TR></TABLE>
When the start starts to go it generally takes anywhere from 5-10 tries of clicking to get it started. The reason I suggested that it was the battery or alternator was because you said it struggled to crank, sometimes the battery will not have enough power to give to the starter either hence the clicking...I'd check the voltage of the battery.
Old Sep 20, 2005 | 05:41 PM
Chewie's Avatar
Default Re: starting issues (xteg95)
get someone to jump your car. If it starts right away, then its probably the battery.
Old Sep 20, 2005 | 06:41 PM
Keno20's Avatar
Default Re: starting issues (Chewie)
yeah I'll agree with them on this one, definitly sounds like the battery. Make sure its charged and also that the leads are on properly (may sound stupid but I dont know how many times i've seen someones car not starting because of the connection to the battery)
Old Sep 21, 2005 | 06:07 PM
sheBangZ's Avatar
car still doing it after recharging the battery, so i'm narrowing down to the starter just acting up. grrrrrrrrrrrr
Old Sep 21, 2005 | 06:18 PM
Greyghostgsrt's Avatar
I KNOW WHAT YOUR PROBLEM IS... your main relay by your hood pop I had same problem
2x0
48
Jun 16, 2018 07:56 AM
rick_rabies
26
Apr 5, 2009 01:07 PM
sohctodohc
Jul 22, 2006 11:17 AM
limitlesstuners
Jan 9, 2005 05:44 PM
t3to4e
Aug 9, 2004 04:50 PM
