d16z6 parts list questions
Old Sep 20, 2005 | 11:32 AM
nunshavenofun's Avatar
Default d16z6 parts list questions
im purchasing a d16z6 head for my 89 rex si was looking for a parts list of what i will need
Old Sep 20, 2005 | 11:34 AM
beyondspexj's Avatar
aside from the complete head you are gunna want to convert to obd1.
p28 ecu, z6 dizzy, z6 fuel injectors, 4 wire o2, obd0-obd1 clip over harness
Old Sep 20, 2005 | 03:56 PM
D16a6Civic_Si's Avatar
Default Re: d16z6 parts list questions (nunshavenofun)
yeah what he said and you can get the conversion wires at rywire.com for pretty cheap make sure the vtec head is complete:vtec seliniod, and internals.
you also wanna get a agasket set for thermostat and head and exhaust manifold and what ever manifold your using stuff like this you really dont need the ecu you can just go and get a vtec controller which if your gonna vtec it you might just want one anyway to set the vtec for your daily driving and your drag racing so i'd just buy that but its your swap do what ya want.
Old Sep 20, 2005 | 05:00 PM
iTe4LIFe's Avatar
Hey there, please correct me if im wrong (for I’m planning on a mini me and haven’t fully looked into it, just briefly in a deep sense), couldn’t he use a pm6 ecu if desired? I knew someone who had a b2 / z6 mini me on a pm6 si ecu with vtec activating on a vafc (if I remember correctly)….
Old Sep 20, 2005 | 06:05 PM
Default Re: (islandtechengineers)
so pretty much it would be better to just get the controller as well as cheaper also i took out the head myself so i got everything includidnt distributor manifold all that so can i use the distributor off the new d16z6 head or do i have to use my old one?
Old Sep 20, 2005 | 06:17 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (nunshavenofun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nunshavenofun &raquo;</TD></TR><TR><TD CLASS="quote">so pretty much it would be better to just get the controller as well as cheaper also i took out the head myself so i got everything includidnt distributor manifold all that so can i use the distributor off the new d16z6 head or do i have to use my old one?
not better but it can be done dont half *** go obd1
Old Sep 20, 2005 | 06:49 PM
Default Re: (Ace$nyper)
so how much would it be to do a complete obd1 swap and what are the EXACT parts i would need
Old Sep 22, 2005 | 10:58 PM
ndondahows's Avatar
4 wire 02 sensor from sparkplugs.com $70
P28 ECU usally $120 shipped
4 z6 injectors used $30-50
Depending on if you want to wire yourself or you want someone rywire to do it $110-190. 110 for jumper harness, 190 for all wiring done for youand jumper harness
New OBD1 distributor is about 159.99 from am-autoparts on ebay (same person rywire buys their stuff from.)
Old Sep 22, 2005 | 11:23 PM
gnar kill's Avatar
Default Re: (ndondahows)
first of all use your STOCK A6 INJECTORS they will work just find there is no point in using the z6 injectors.....please convert to obd 1 you will be much happier since vtec is more than an on off switch that just kiks in.....you need the proper fuel maps for the vtec cam.....it is not hard. you have to use obd 1 dizzy otherwise the bolts don't line up from the a6 dizzy......
Old Sep 23, 2005 | 12:45 AM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndondahows &raquo;</TD></TR><TR><TD CLASS="quote">4 wire 02 sensor from sparkplugs.com $70
New OBD1 distributor is about 159.99 from am-autoparts on ebay (same person rywire buys their stuff from.)</TD></TR></TABLE>
We have factory o2 sensors too....
Old Sep 23, 2005 | 11:10 AM
Default Re: (droppedcrxsi)
ok i got the distributor for free and the ecu for 40 bucks if i wanted to wire it myself how would i go about doing this?
Old Sep 23, 2005 | 02:47 PM
gnar kill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nunshavenofun &raquo;</TD></TR><TR><TD CLASS="quote">ok i got the distributor for free and the ecu for 40 bucks if i wanted to wire it myself how would i go about doing this?
if you have to ask I recomend buying the conversion harness.....I did
cdavies
Jun 18, 2010 01:24 AM
EJeremy6
May 18, 2010 07:37 AM
SWAT
Engine Management and Tuning
Apr 25, 2010 02:43 AM
gophat
Sep 11, 2006 06:29 AM
