take out a valve.
Old Sep 20, 2005 | 09:05 AM
mycrx7's Avatar
Default take out a valve.
i plan on keeping the head on just looking for a quick fix for now someone who had this ls head b4 put the valve spring upside down yay what morons but ya i need to fix it right now any suggestions? how do i get the valve out.
Old Sep 20, 2005 | 09:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: take out a valve. (mycrx7)
umm you can't remove a valve unless you pull the head.
You can remove the valve spring and retainer, but you have to have a special snap-on tool that allows removal without pulling the head off. It's a bar that bolts across the top of the head and a tool that rotates against the bar and allows you to push down on the valve retainer, remove the keeper, and then remove the valve spring. Otherwise a standard valve spring compressor requires head removal.
Old Sep 20, 2005 | 09:19 AM
DarkDragon's Avatar
Take the valve cover off, u need to get a fitting that threads into the sparkplug hole and use a air compressor to pressureize the cylinder. Make sure that cylinder in a BDC because if it isnt the air will push the piston down and might break something. Then using the appropriate size wrench lossen the valve lash lock nut and then move the rocker out of the way to expose the ratainer and the spring. from there u need a valve spring compressor tool to push it down (the air will keep the valve up) and remove the keepers and flip the spring over then it in reverse
Old Sep 20, 2005 | 01:44 PM
Community Builder
Default Re: take out a valve. (DarkDragon)
yeah but still, he's going to need that Snap-on valve spring compressor tool to be able to do it with the head still on.
Old Sep 20, 2005 | 08:32 PM
DarkDragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon &raquo;</TD></TR><TR><TD CLASS="quote"> from there u need a valve spring compressor tool to push it down (the air will keep the valve up) and remove the keepers and flip the spring over then it in reverse</TD></TR></TABLE>
I said he would need a VS tool..... the one u listed with the bar would be wasier but he could get one that mounted on the rocker pivit also
Old Sep 21, 2005 | 07:03 AM
mycrx7's Avatar
i got the spring and stuff out just need to get it back in, **** i dont want to have to pull this head off again, how much is that tool and where can i buy it.
Old Sep 21, 2005 | 08:54 AM
DarkDragon's Avatar
did u use a tool to compress the spring to remove the keepers and retainer? and you did pressurize the cylinder correct? if you didnt and the piston was near TDC and you pushed the spring down the valve could have hit the piston and have bent which then you would need to remove the head.
Old Sep 21, 2005 | 10:38 AM
Community Builder
Tool runs about $130 to $150 from Snap-On I believe.
Old Sep 22, 2005 | 07:34 AM
mycrx7's Avatar
Default Re: take out a valve. (PatrickGSR94)
naw i need this motor running dont care how well its together just need my car, i compressed the spring took it all apart then hahah **** i cannt beleive i did it, just zip tied that spring down and wala cleared just enough to put in the keepers! **** quite fix runs great now. lol thanks for the help though guys, and that snap on tool woulda came in handy.
Old Sep 22, 2005 | 07:37 AM
projectTeG's Avatar
valve springs can go in upside down? i thought you could only switch the int. and ex sides.
Old Sep 22, 2005 | 05:42 PM
mycrx7's Avatar
Default Re: (projectTeG)
ya the tight end of the coils where facing up.
Old Sep 22, 2005 | 07:04 PM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 &raquo;</TD></TR><TR><TD CLASS="quote">naw i need this motor running dont care how well its together just need my car, i compressed the spring took it all apart then hahah **** i cannt beleive i did it, just zip tied that spring down and wala cleared just enough to put in the keepers! **** quite fix runs great now. lol thanks for the help though guys, and that snap on tool woulda came in handy.</TD></TR></TABLE>
Those most be some burly *** zip ties. I want some.
Old Sep 22, 2005 | 08:03 PM
projectTeG's Avatar
Default Re: (mycrx7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 &raquo;</TD></TR><TR><TD CLASS="quote">ya the tight end of the coils where facing up.</TD></TR></TABLE>
were they stock springs?
BoostdRex
Jul 30, 2007 07:07 AM
sauceja
Feb 24, 2006 07:46 PM
WhiteNess
Nov 7, 2005 05:04 AM
MisterB
Jun 4, 2003 09:31 PM
JunIntegra
Apr 11, 2003 05:15 PM
