Replaced pads and rotors and brakes squeaking/ squeeling
Old Sep 20, 2005 | 07:26 AM
Toneman14's Avatar
Default Replaced pads and rotors and brakes squeaking/ squeeling
My pads and rotors are brand new all around. I have powerslot rotors (slotted/dimpled) with hawk pads in the front and AEM pads in the rear. The fronts squeel pretty bad and it's starting to get annoying. They wont squeak if I brake hard, just light braking. When I installed them I didnt use brake lube on the pads, could this be why?? If this is the reason should I take em off and put some on?? would that cure the problem or does it not matter?
Old Sep 20, 2005 | 07:32 AM
BlackLudeSi's Avatar
Default Re: Replaced pads and rotors and brakes squeaking/ squeeling (Toneman14)
Yes your brakes are squeaking beacause either the goop was not put on the pads and/or your anti-rattle clips are going bad. Its is not a safety issue however like you said it is getting annoying. So if you want to stop the squeaking definetly put the goop on the back of the pads and you might want to look at doing you anti-rattle clips at the same time
Old Sep 20, 2005 | 08:06 AM
green_GSR's Avatar
Which Hawk pads are you using? I tried many Hawk pads in the past, and they all squeel.
Old Sep 22, 2005 | 06:48 AM
Toneman14's Avatar
Default Re: Replaced pads and rotors and brakes squeaking/ squeeling (green_GSR)
Well I know theres two different kind and I think I'm using the high performance ones. I havent put the goop on em yet but hopefully this saturday I can get some free time to do it. I'll let you guys no how it goes.
Old Sep 22, 2005 | 07:22 AM
crx_88_si's Avatar
performance pads are louder than stock as well.
you have two things contributing to the noise
Old Sep 23, 2005 | 07:06 AM
Toneman14's Avatar
Default Re: (crx_88_si)
When you say loud to mean over all noise or just the squeaking itself
Old Sep 23, 2005 | 08:29 AM
LSvtec03's Avatar
Default Re: (Toneman14)
the retainer clips shouldn't be causing any noise, but the lack of grease on the pads sure can. grease the slide pins while you're at it.
clem kevin
Aug 11, 2008 03:51 PM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
Tad
Jun 22, 2005 12:30 PM
accordhybrid
May 23, 2003 12:58 PM
timbuktu
Mar 22, 2002 12:50 PM
