Where 'o' where is my FITV?!
Old Sep 20, 2005 | 06:35 AM
BigRonDawg's Avatar
Default Where 'o' where is my FITV?!
I have a 96 dx hatch, with a D16y7 stock engine.
I'm planning on dropping a B18 in it but until then it's my daily driver and just recently my idle has been surging.
I found LOTS of things it can be, but the only thing i haven't been able to find is the FITV (Fast Idle Thermo Valve).
I have an EX coupe and i can see it clear as day, but on the DX i can't find the bugger...
I'm thinking it's part of the throttle body but i'm not sure.
Anybody know about this on a D16y7?
Old Sep 20, 2005 | 07:18 AM
BigRonDawg's Avatar
Do D16y7's even have a FITV?
Old Sep 20, 2005 | 09:53 AM
perlmeister8's Avatar
Default Re: (BigRonDawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigRonDawg &raquo;</TD></TR><TR><TD CLASS="quote">Do D16y7's even have a FITV?</TD></TR></TABLE>
No they dont.
Old Sep 21, 2005 | 09:29 AM
egyolk's Avatar
Default Re: (perlmeistere81)
so if thats the case you might wanna try just cleaning ur IAVC i'm in the process of doing mine, goodluck with ur surging
Old Sep 21, 2005 | 09:37 AM
mike1114's Avatar
Default Re: (oversteerINGS)
sounds like vacuum leak.
Use carb cleaner and spray it all over your intake manifold, around all gasket areas and what not. IF you engine stumbles or dies, there is your vacuum leak.
Old Oct 10, 2005 | 02:10 PM
silverboost's Avatar
Default Re: (mike1114)
wat does a d16y7 use to control idle?
si90rex
Jun 24, 2007 07:12 PM
minime-civic
Apr 27, 2007 02:22 PM
UNDER PRESSURE
Nov 22, 2005 03:30 PM
LilCivic04
Sep 9, 2005 11:28 PM
dingusjt
May 13, 2003 10:12 AM
