Looking to build a 180 whp ls/vtec motor
Old Sep 19, 2005 | 10:40 PM
racer034life's Avatar
Default Looking to build a 180 whp ls/vtec motor
OK i am looking to make around 190 or so with some stock honda parts. This is my set-up so far. Can anyone give me some tips on things i should and shouldnt do.
Bottom end:
LS block hot tanked cleand blue printed and balanced
Crank micro polished and balanced
manley rods
CTR pistons
ITR oil pump and water pump
Head:
GSR
omni man valve train
CTR and ITR cams
3 angle head job
Skunk2 cam gears
These are the main things of my build clutch and flaywheel will be act. my tranny is a ITR with the LSD. As for fuel rail, regulater and injectors i havent really given much thought. So what should i change and what do i need to make better. Thanks all
Old Sep 20, 2005 | 12:36 AM
Cherchez La Ghost's Avatar
Default Re: Looking to build a 180 whp ls/vtec motor (racer034life)
do you realize how high your comp will be with CTR pistons and GSR head?
Old Sep 20, 2005 | 01:10 AM
Trixiem's Avatar
Default Re: Looking to build a 180 whp ls/vtec motor (Lekz)
it'll be risky running that with pump gas. actually it could be done if you don't beat on it too much.
-kenny
Old Sep 20, 2005 | 02:46 AM
hybridpatient95's Avatar
with a good tuner.. and a good tune you can beat on it as much as you want.. what octane do you have around you?
Old Sep 20, 2005 | 08:18 AM
Default Re: (frankenfiend 04)
Here in ohio i can get 120 octane but i would have to go the the drag strip or get it off of a race team. But i was thinking of running 110 octane with this set-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lekz &raquo;</TD></TR><TR><TD CLASS="quote">do you realize how high your comp will be with CTR pistons and GSR head? </TD></TR></TABLE>
no i dont really i havent put the numbers together its just a head a friend of mine has setting around. would a B16 head be a better choice.
Old Sep 20, 2005 | 10:44 AM
Ekay Jay's Avatar
If i was u i would get some pr3 or p30 pistons. U can alwasy raise your comp by getting a 2-layer headgasket in the future if u decide to get some bigger cams.
Old Sep 20, 2005 | 12:38 PM
with a gsr head your compression is going to be 13 or so with a b16 head its 12.8.. im doing a ls vtec with ctr's but with a b16 head i like those better for some reason
Old Sep 20, 2005 | 12:40 PM
DonF's Avatar
Does Manley make a press in rod? If not who is going to cut the circlip grooves in the pistons?
Old Sep 20, 2005 | 02:46 PM
Rocket's Avatar
Default Re: (DonF)
You would need to cut for spriolox unless you plan to chamfer the end of the pins to run round wire circlips.
Old Sep 20, 2005 | 02:59 PM
Toadfart's Avatar
Default Re: (Rocket)
Can someone elaborate on circlips and spirlox? Would CP pistons and eagle rods have any issues with either circlips or spirlox whatever they may be?
Old Sep 20, 2005 | 03:17 PM
RudeBwaiSi's Avatar
Circlip (c-clip) is that circular wire that locks the piston pin in place.
Not sure bout the spriolox thing but I am thinking its similar to a C-clip. Just different pistons use them.
Old Sep 20, 2005 | 03:34 PM
Default Re: (Toadfart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Does Manley make a press in rod? If not who is going to cut the circlip grooves in the pistons?</TD></TR></TABLE>
Yes they do but they are around 600 or so.. but i just talked to tim for bazeracing here in cinicnnati and im going to change a few things here are the changes...
Head
jun valve springs and retainers
Rev valves
skunk2 pro cams stage 2
stage 2 valve job port and polished 2 angle
Bottom End
Cp pistons
eagle rods
balanced and blueprinted ls crank
itr water and oil pump
all new acl honda bearings
There is the new set-up what do you all think
Old Sep 20, 2005 | 04:42 PM
DonF's Avatar
Default Re: (racer034life)
Sounds better, get the ACL race bearings. And why use 3 diff mfg. for your valve train? If you have problems, they can each blame the other. I really like the Sk. Pro2's but you do need a goog head and intake to see all the high RPM gaines.
Old Sep 21, 2005 | 12:33 AM
Default Re: (DonF)
I havent really seen anything or anyone running the new skunk2 pro 2 series stuff. but i will look into it. Also im getting a custom set of ITB's for my car. thats about it......anything else i need to add
Old Sep 21, 2005 | 12:43 AM
fmrprojects's Avatar
get a really nice header, tune that ****, and you'll make way over 190hp. good luck with your build
Old Sep 21, 2005 | 06:43 AM
jdm123's Avatar
Default Re: (fmrprojects)
http://www.c-speedracing.com/h...c.php that should help or you can just mess around, i dont know.
Old Sep 21, 2005 | 11:09 AM
Default Re: (jdm123)
Yea just got me Ls block today and the head Im going with a b16 head also. I will be posting pictures with in a few weeks.....
Old Oct 2, 2005 | 10:07 AM
ernald711's Avatar
looks to me that you've done your research before jumping in on a post. you'll make your expected numbers. i'm making 175whp with these mods.
1998 B18B Block (honed, hot tanked, and thoroughly inspected)
LS Crank (balanced {cam to flywheel} and micropolished)
Modified ITR Main, Rod, and Thrust Bearings
LS Rods (ARP lock bolts)
B18C5 P73 Pistons (New)
P73 Piston Rings
B16 Head reconditioned w/new valve job,etc...
ITR Oil and Water pumps (New)
ITR Crank pulley
LS Oil pan, windage tray, and pickup
Hondata Intake Manifold gasket
All brand new OEM gaskets and seals for top and bottom end
The block cleaned with a fresh hone, decked, and bored out .25 for oversized pistons.
As for the ECU, i went p28 Hondata s200.
here's my thread.. check it out
https://honda-tech.com/zero...age=4
Old Oct 2, 2005 | 10:26 AM
yes i have done some what of my home work. but there is alot more i can learn. I want to see what a gsr block with ls crank, ls sized crower rods, Cp pistons. i want to make so where around 190 or so and i want to be able to beat the crap out of my motor and still have the room to drive it some places.
Old Oct 2, 2005 | 10:30 AM
BJOnewiper's Avatar
Very good thread, Ernald...I'm gathering parts for something very similar (but I'm going straight B18b-ITR pistons overbored, B18b head for the winter.)
MR.johnson
Jul 21, 2014 02:31 PM
ekVic214
16
Sep 5, 2011 01:34 PM
ej1b18b1
31
Oct 8, 2009 12:14 PM
hatchdrvr
Aug 8, 2003 04:08 PM
hatchdrvr
Aug 8, 2003 12:51 PM
