Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP!
Old Sep 19, 2005 | 07:47 PM
petersayarath's Avatar
Default Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP!
So, i was driving one night with my new turbo set-up just installed the day before.. everything was working fine.. Then for 2 days it was raining from the aftermath of Hurricane Katrina. The next day i go to start up my car, it cranked but didnt start cuz moisture cant into the dizzy and plus i flooded the motor trying to start it. i fixed the problem start it up and NOW my RPM on my stock cluster doesn't work but everything else does.. I swapped my friends cluster and it did the samething. Checked the fuses, wires in the back of cluster.. still nothing.. ANything guys.. HELP!
Old Sep 19, 2005 | 07:58 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP! (petersayarath)
Double check your wires. If your buddies guage was working..
Old Sep 20, 2005 | 02:48 PM
i did but nothin... anything else.. is there another fuse that im unaware of? like in the cluster itself? anything?
Old Sep 20, 2005 | 03:03 PM
blackie's Avatar
which fuse did u check? mine happened cause of the speed sensor one? i think. rpm went out then speedo then whole car dimmed then battery died. that fuse was the prob to the wholllle thing
Old Sep 20, 2005 | 04:15 PM
postman's Avatar
id check to see if your speed sensor on yur tranny is ok, might have got water into and jacked it up
Old Sep 20, 2005 | 04:46 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP! (postman)
Check fuse #15 in the underdash box and check the backup fuse in the engine bay box.
Old Sep 20, 2005 | 09:30 PM
Default Re: (blackie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackie &raquo;</TD></TR><TR><TD CLASS="quote">which fuse did u check? mine happened cause of the speed sensor one? i think. rpm went out then speedo then whole car dimmed then battery died. that fuse was the prob to the wholllle thing</TD></TR></TABLE>
theres a speed sensor fuse? where is that located?
Old Oct 11, 2005 | 12:09 PM
Tuan's Avatar
Default Re: (petersayarath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petersayarath &raquo;</TD></TR><TR><TD CLASS="quote">
theres a speed sensor fuse? where is that located?</TD></TR></TABLE>
I didn't know that there was a speed sensor fuse either?
ek9=]
Jul 16, 2009 04:19 PM
SIR EF9
Dec 20, 2008 01:05 AM
TA Performance
Audio / Security / Video
Mar 27, 2007 06:23 AM
Civicvtihatch
Sep 16, 2004 10:28 AM
juanb
14
Dec 17, 2003 08:21 PM
