HELP... 92 civic dx 4dr Tie-Rod question
The front driver side tire has some give. when accelerating it will pull to the side i last did a stering correction on . It doesn't seem to striaghten out. Now i looked at the tie rod and seems fine the nothiced that the inner tie rod boot was not clasped and had a a bit of rust. Now my question is... does the inner tie rod have an adjustment (for if somehow it came loose ...i don't know if that is common or not) or does it lock in place somehow and poped out. i thought about adjusting the outer tie rod to pull it in but if the give is from the inner tie rod it wont make differance. HELP. sorry for the long post and i dont' even know if it made sense.
SlammedBlueEM2
Aug 4, 2004 04:45 PM
