Whirring noise from tranny???
Old Sep 19, 2005 | 04:55 PM
LvN's Avatar
LvN
Default Whirring noise from tranny???
Here's my situtation...
I have a b16a (99-00 SI) transmission. Whenever my car is on, a whirring noise is coming from the transmission. When I apply the cluth it stops. Then once I put it on first gear and give it some gas, it gets louder like a bunch of screws are rumbling inside the tranny.. It happens on 1st, 2nd, and 3rd gear. I've changed the transmission oil with some Syncromesh, but it's still there.
Old Sep 19, 2005 | 05:09 PM
m00nr0ck Si's Avatar
Default Re: Whirring noise from tranny??? (blkcivicpn0i)
it sounds like your throw-out bearing may be fubard. whirring noise when under a load or driving is normally the input shaft bearing. but just idling I would almost bet you anything its the throwout!
Old Sep 19, 2005 | 05:13 PM
LvN's Avatar
LvN
Default Re: Whirring noise from tranny??? (dorkoftheyear)
I'll check that when I take my tranny off.. thanks.. Anyhow, do you know how much it'd be to replace it?
Old Sep 19, 2005 | 09:03 PM
LvN's Avatar
LvN
Anyone else?
Old Sep 19, 2005 | 09:44 PM
E46Kid's Avatar
when the car idles hear noise? (tranny) and then when u hit clutch the noise stops ? tranny is screwed for sure..had that on my hb.... sold it before it just went out..
Old Sep 19, 2005 | 10:06 PM
mikey-ej7's Avatar
Default Re: (00EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00EM1 &raquo;</TD></TR><TR><TD CLASS="quote">when the car idles hear noise? (tranny) and then when u hit clutch the noise stops ? tranny is screwed for sure..had that on my hb.... sold it before it just went out..</TD></TR></TABLE>
Are you shitting me??? My cx is doing that now. It's like a light whirring at idle and I step down and it shuts off
what should I do??
Old Sep 19, 2005 | 11:45 PM
ziich2's Avatar
Default Re: (mike-94eg)
throwout bearing is going bad and needs replacement. That requires pulling your tranny off, it's a good opportunity to replace your clutch/flywheel and be sure sure to replace the other bearings because it's a bitch to get off. It'll be worth your time.
You all should tend to that soon, it will only get worse the more you drive it.
Old Sep 20, 2005 | 01:07 AM
siregcivic's Avatar
Default Re: (ziich2)
it could either be your throwout bearing or ur input shaft bearing
Old Sep 20, 2005 | 03:35 AM
CardDealer's Avatar
Banned
Default Re: (siregcivic)
Modified by CardDealer at 4:32 PM 11/16/2006
Old Sep 20, 2005 | 05:59 AM
TurboSI24's Avatar
Default Re: (schlit)
its your input shaft bearing, cause i just changed my clutch and flywheel and was told its that bearing. I have the same problem, and you tranny is not going out ive been riding like that for over 30k miles and still like new.
Old Sep 20, 2005 | 06:41 AM
ill3galdr1v3r's Avatar
you guys think that this problem would be covered by warranty?
i bought a used black EM1 from the stealership, and it has a 3 year 36,000 mile warranty.. i am having this same problem.. hopefully its covered by the warranty. i sure hope so!!! hopefully a free tranny rebuild
Old Sep 20, 2005 | 07:24 AM
92BluEH-3's Avatar
lulz
yea its gunna be your throw out bearing and input shaft you might need a new tranny if you fell like it cuz that happen to me on my tranny.
Old Sep 20, 2005 | 07:59 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like your throw-out bearing may be fubard. whirring noise when under a load or driving is normally the input shaft bearing. but just idling I would almost bet you anything its the throwout! </TD></TR></TABLE>
Old Sep 20, 2005 | 12:06 PM
.Ry's Avatar
.Ry
Default Re: Whirring noise from tranny??? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-94eg &raquo;</TD></TR><TR><TD CLASS="quote">
what should I do??</TD></TR></TABLE>
Mine does the same thing, but only when the car is warming up. Seems like a Honda thing, dont worry about it.
Old Sep 20, 2005 | 12:31 PM
pdiggitydogg's Avatar
https://honda-tech.com/zerothread?id=1377148
Think about it, if the noise only shows up when the clutch is pressed, there is pressure on the throwout bearing - which would make that noise then, and only then.
If the noise is when the cluth is NOT pressed then its the input shaft bearing.
Remove the tranny, separate the housings, replace the bearins on the input shaft.
Bauley has written a how-to, I suggest you look for it (served me very well when I replaced my ISB, over the winter)
Old Sep 20, 2005 | 12:40 PM
.Ry's Avatar
.Ry
Default Re: (pdiggitydogg)
I understand that, but mine just sounds like the motor is louder and when you press in the clutch it get quiter. Car shifts like brand new no questions asked.
Old Sep 20, 2005 | 01:33 PM
CardDealer's Avatar
Banned
Default Re: (turner7205)
Old Sep 20, 2005 | 01:46 PM
.Ry's Avatar
.Ry
light touch.
Old Sep 20, 2005 | 02:11 PM
CardDealer's Avatar
Banned
Old Sep 20, 2005 | 02:34 PM
ABK's Avatar
ABK
It's input shaft bearing. Probably the first one but I would check out the back one while you at it too. I've seen cars run with all the ***** in the bearing crushed, with like 1/4" of shaft play, and you couldn't even tell unless you listen to it.
if it was throw out bearing the noise would appear when you press the clutch in.
Old Sep 20, 2005 | 02:39 PM
EK k kay's Avatar
Default Re: (ABK)
Probably the input shaft bearing like said above. I had that whirring noise too. Check the mainshaft bearing as well if you take apart the tranny. I replaced both and the noise went away.
Old Sep 20, 2005 | 05:07 PM
.Ry's Avatar
.Ry
Default Re: (chowmien)
Well I guess in my case its not the whirring noise. If you press the clutch in all the way the rmps goes down. Kind of sounds like the there is a load being lifted off the engine when you press in the clutch, and the tranny stops spinning.
Old Sep 20, 2005 | 05:29 PM
cjkdelsol's Avatar
From what you are saying I would be sure that it is your input shaft bearing or honda calls it the mainshaft bearing that sits in the clutch housing. I have replaced this bearing on 2 D series transmissions and the problem was solved. bauleycivic have a very good write up but it is on the d series. In his write up someone else has one on the b series. It is really easy to do. Once you have the tranny out it will only take about 30 min to crack the tranny and replace the isb. Believe me the first time I was unsure of being capable of doing this job but if you are mechanically inclined i believe that anyone can do it if they really want to. The main reason why i did it in the first place is the cheapest estimate just to replace that one bearing with the tranny already out was $500.
Old Sep 20, 2005 | 05:36 PM
.Ry's Avatar
.Ry
Default Re: (cjkdelsol)
Hell its not even a noise at all. Just when you disengage the clutch the idle goes down and the tranny isnt spinning anymore so the sound of the tranny spinning goes away.
Old Sep 20, 2005 | 06:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill3galdr1v3r &raquo;</TD></TR><TR><TD CLASS="quote">you guys think that this problem would be covered by warranty?
anyone?
