quickie question....which side of the axle would wear out faster????????????
i have a 96 gsr..my question is which side of the axle would break faster when you race?
Do you mean which cv joint, the inner or the outer? Most of my axles wear on the outer cv joint first, but when my rear mount bracket bolts vibrated out, the inner cv joint went out and caused a ton of vibration during acceleration. I replaced the rear mount bolts, installed a new dr side axle, and all is fine again. I also have heard that if you are slammed, the inner joint takes a beating.
Rocks
Jun 28, 2004 11:06 AM
