E-manage base map
i have a 98 turbo gsr. i was wondering if any one has an e-manage base map i could use as a starting point. injector size is 310cc running 10psi
thanks for any help
Modified by turboGN at 12:57 PM 9/19/2005
thanks for any help
first off get ride of that emanage that thign is a piece of ****, its a mera piggy back fuel computer. i have 01 turbo gsr, and at 10 psi your injectors won't be able to handle it, u need at least some 450cc injectors, and i would also seriously think about upgrading your ecu!! i currently am using a p28 ecu chipped and tunned with crome pro, and i have 450 cc injectors to be able to run 10 psi.
i would serious rethink your idea of running the emange its not a very useful tool IMO, especially if u want to bump your boost up, i would look into something esle, also u need larger injectors and a larger fuel pump is a nice add too if u want to run 10 psi your 310 just simply can't handle it, i have no idea why u bumping it i told u this earlier, seeing how i did my whole turbo and i did the tunning of it myself i know what i am talken about, and i am assuming u have a greddy kit
bewstn ex
Mar 16, 2008 07:01 PM
