rear disk brakes on a ek?
my boy jus hookd me up with rear disk brakes for my ek. i need to know what else i need. i got the lower control arm with everthing on it but do i need to change anything on my car and do i need anything else? is it jus bolt on and hook up the brake lines? thanks for the help.
you wont NEED the ebrake lines you can use the ones on there but they just wont mount up to the same locations on the underside of the car. youll have to zip tie them up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">you wont NEED the ebrake lines you can use the ones on there but they just wont mount up to the same locations on the underside of the car. youll have to zip tie them up.</TD></TR></TABLE>
you do realize drum e-brake and disc e-brake have different ways of attachment at the hub, right? WOn't work
I do realise that ive done the swap and they do work when swaping the entire trailing arm. http://repo.jackmoves.com/album55
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">I do realise that ive done the swap and they do work when swaping the entire trailing arm. http://repo.jackmoves.com/album55</TD></TR></TABLE>
Ah, you were talking about using the e brake lines that come with the rear brakes...I gotcha now.
I thought you were saying he could use his existing e brake lines from the drums to work with the disc, and that's a negative.
you need integra barkes lines if there from an integra,or if there from an si then i think your will work and you need the e-brake cables also....
warwagon
Jun 22, 2004 03:53 PM
1 speedstar
10
May 23, 2003 06:26 PM
1993EG6
Dec 2, 2001 02:00 PM
