can someone help me with installing fog/driving light instruction?
I pretty much understand the intructions given by the company, only question is, where do I connect the ground wire to, and in the diagram there's a wire connecting to the low/high beam, how do I connect that?
can someone simplify the steps
thanks
thanks
there is a little blueor brown din connector right behind the driver headlight assembly. this is where the factory fog light power cord connects from the fog light to the electrcal system. find out which one is the ground and which one is the hot wire. only one problem though, if you have a remote power supply switch for the fog lights, you have to find a way to hook it up. i spliced into the ashtray light(which only comes on when the lights are on). that way my switch for the fog lights only illuminates and provides power to the fog lights only when your lights are on(something to think about if you have an illuminated switch, i personally wouldn't want to have to replace the bulb in the switch because it is always on). good luck!
civicSIfnatic
13
Aug 21, 2008 09:48 PM
honda95civic
Audio / Security / Video
Jul 20, 2006 08:16 PM
