how do you guys remove the shift linkage of the tranny? asap!!!
Old Feb 28, 2002 | 04:07 PM
AzN_Flava's Avatar
Default how do you guys remove the shift linkage of the tranny? asap!!!
okay... i have the reverse gear linkage taken off.. and i have left is the one that controls the 5 speed linkage....
i took off the metal clip... and it looks like there is a pin in there... is this supposed to be drilled out? help.. i gotta ship it soon... and id ont want to damage it...
Old Feb 28, 2002 | 04:09 PM
EP3_05's Avatar
Default Re: how do you guys remove the shift linkage of the tranny? asap!!! (AzN_Flava)
You need an 8mm non tapered punch and a hammer. You then can bang it out and pull the linkage off. You could always use a screwdriver but that might get tough especially if the pin gets stuck in there.
Old Feb 28, 2002 | 04:16 PM
Katman's Avatar
the perfect bolt for taking the shift linkage's PIN out ...is using an AC compressor's mounting bolt. Yeah, the long one (I think it's a 12mm or 14mm bolt). Get one, a hammer, some WD-40, and pound away...and it should come right out.
Old Feb 28, 2002 | 04:46 PM
-TJ's Avatar
-TJ
Default Re: how do you guys remove the shift linkage of the tranny? asap!!! (Katman)
Yeah....don't plan on ever re-using that A/C bolt again though. You can also use a 5/16 straight (non-tapered) punch which may be more widely available than 8mm. (The 5/16 punch is .003" smaller in diameter than the 8mm.)
Old Feb 28, 2002 | 06:33 PM
TurboMiata's Avatar
Default Re: how do you guys remove the shift linkage of the tranny? asap!!! (-TJ)
make sure you dont shoot that little pin halfway across the garage like I did..... Its not the easiest thing to find, and you will need it when you put it all back together.
Old Feb 28, 2002 | 07:29 PM
C-speed's Avatar
Default Re: how do you guys remove the shift linkage of the tranny? asap!!! (TurboMiata)
Merry xmas - second to last pic:
http://www.c-speedracing.com/howto/b18cswap/swap.html
Old Mar 2, 2002 | 07:50 PM
AzN_Flava's Avatar
Default Re: how do you guys remove the shift linkage of the tranny? asap!!! (G3-TEG)
Just posting to say thank you ppl thanx for all the help... great pictures g3teg
heheh to think my buddy was going to drill it out!
hehe thanx again ht buds!
Dr.Fixit
Oct 22, 2013 12:42 AM
MikeY326
Dec 27, 2009 10:35 PM
redboost10
Jul 22, 2007 06:58 AM
BigDawwg6969
Aug 16, 2005 09:59 AM
kshymkiw
Dec 3, 2002 07:21 PM
