Car will not start
Old Sep 19, 2005 | 09:21 AM
91hatch757's Avatar
Default Car will not start
When i turn the key the motor cranks but does not start.
The main relay does work
I smell fuel....so i know i have no fuel delivery
when i pull the #1 plug I get a spark every 4 revolutions
I can hear the starter engaging the flywheel and also see the crank pulley and cam pulley turn
It has a brand new distributor cap and main relay
Btw it is a d15b2
Please help I'm at wits end
Old Sep 19, 2005 | 10:21 AM
boonacka's Avatar
Default Re: Car will not start (91hatch757)
does it feel like it wants to start but doesnt stay running? - ignition switch
do all dash warning lights appear when the key is turned to ON position?
Also replace ignition rotor & coil.
Old Sep 19, 2005 | 11:12 AM
91hatch757's Avatar
Default Re: Car will not start (boonacka)
does it feel like it wants to start but doesnt stay running? - ignition switch...
all the dash lights turn on when the switch is put in the #2 position
most of the time its just the starter turning the motor but i just got it to run as long as the starter was cranking
ignition rotor?....its only 2 months old and the cap is 2 maybe 4 days old
Old Sep 20, 2005 | 07:22 AM
91hatch757's Avatar
well know ive got it running again....it ran fine yesterday but today the idle is all over the place i think the car is cursed
Old Sep 20, 2005 | 07:26 AM
rolledthatho's Avatar
so what did you do
a few more things i was going to suggest were, clutch saftey switch and grounds
Old Sep 20, 2005 | 08:48 AM
boonacka's Avatar
Default Re: (rolledthatho)
what has been done to the hatch? any mods etc bone stock, prior history of problems .....
UndergroundTrev
Mar 27, 2016 10:15 AM
CptHMCrunch
Apr 1, 2014 11:03 AM
Hughes07
Mar 26, 2013 05:24 AM
kevpple
Nov 14, 2010 04:05 PM
JToolz
Feb 15, 2004 06:56 PM
