clutch has no presure! Help?
Old Sep 18, 2005 | 11:07 PM
mr.tom's Avatar
Default clutch has no presure! Help?
So driving home from work one morning I noticed the clutch was engaging alittle rough, so i pulled over and noticed my fluid was alittle low so on my way home I picked up some brake fluid and went home, on the way home the clutch was getting worse and worse by the time i had done my 10 mile drive home I had no clutch at all. Push it to the floor and it wouldnt engauge nor would it even come up off the floor. So about 20 rev matches latter i get home and say screw it i'll do it after i wake up. Well when i get up I grab my brake fluid and fill the tank up (by this time there was no fluid in there at all, also i couldnt find where any of it leaked out) After cleaning up I got in my car started it in nutral depressed the clutch and still no presure. No more fluid has leaked out since (becuase there isnt enough pressure to make it)
So i traced the clutch line and no holes or anything. I can only assume that is the master cylineder but i really dont know how to check to see if that is it or not. Im kinda newb when it comes to hondas so i can only assume what i was looking at was my master cylinder (kinda by the intake on the front of the engine.....right?) Well anyways if you guys have any ieads on what i should be looking out for please give me some help here, becuase i know if i drive it too a shop then they will tell me its your clutch, your master cy. and your slave cy. and i really dont want to deal wityh there bs.
Old Sep 18, 2005 | 11:41 PM
mr.tom's Avatar
Default Re: clutch has no presure! Help? (mr.tom)
bump becuase i need some help soon
Old Sep 19, 2005 | 12:36 AM
PURPLETERROR aka BIGMATT's Avatar
your clutch master cyl is on your firewall to the right of your brake booster, your slave cyl is on the front of the transmission. start by filling your master cyl, then bleed your slave cyl, you will need another person, and an 8mm box end wrench
Old Sep 19, 2005 | 06:14 PM
Mista Bone's Avatar
D Tranny Guru
never seen a CRX with a hydro clutch system..........
redline7
Feb 17, 2008 12:24 PM
sniperslayer
17
Nov 5, 2005 06:29 PM
mr.tom
Sep 20, 2005 03:29 AM
eL
23
Sep 21, 2004 03:40 PM
