ITR headers on a GSR question.
Old Sep 18, 2005 | 08:33 PM
Nataku's Avatar
Default ITR headers on a GSR question.
I was told they are a little long and I would need a shorter cat, is this right?
Old Sep 18, 2005 | 08:36 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: ITR headers on a GSR question. (Nataku)
Yes
Old Sep 18, 2005 | 09:09 PM
Squad1's Avatar
Default Re: ITR headers on a GSR question. (ahrpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr &raquo;</TD></TR><TR><TD CLASS="quote">Yes</TD></TR></TABLE>
Old Sep 18, 2005 | 09:34 PM
Nataku's Avatar
Default Re: ITR headers on a GSR question. (NAisbest)
so the solustion would be to just buy the header and cat for a ITR?
Old Sep 18, 2005 | 09:49 PM
That's what I would do, the thing about the GSR header is your going to have to get a custom cat or B pipe(test pipe.)
Old Sep 19, 2005 | 01:07 AM
Chewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr &raquo;</TD></TR><TR><TD CLASS="quote">That's what I would do, the thing about the GSR header is your going to have to get a custom cat or B pipe(test pipe.)</TD></TR></TABLE>
b pipe is the piece with the flange from the end of cat to the begining of the axle back.
Old Sep 19, 2005 | 02:49 AM
plamauski's Avatar
Default Re: ITR headers on a GSR question. (Chewie)
should be real cheap to have a muffler shop fab a custom b pipe
Old Sep 19, 2005 | 02:53 AM
bee18see1's Avatar
Default Re: ITR headers on a GSR question. (plamenski)
I got a DC 2.5 header for ITRs, called up IPSRacing with what I needed for a cat and it fit perfectly. No need for any custom work.
Old Sep 19, 2005 | 06:45 AM
.water's Avatar
any chance to know how long is cat?? on what year integra
Old Sep 19, 2005 | 06:59 AM
Nataku's Avatar
Default Re: ITR headers on a GSR question. (bee18see1)
I really want to do this swap... so what do i need?
Old Sep 19, 2005 | 07:09 AM
purplegsr's Avatar
It all depends on the year GSR you have, also, I am assuming you are talking about the JDM ITR 4-1. The USDM ITR header is the same measurement as any other LS or 00-01 GSR header.
For 94-99 you will need a shorter (~12" cat) and it will need either no or 1 o2 bung, depending on the year of your car. 94-95 will need no o2 in the cat anymore, since the JDM ITR has it in the collector, while in 96-99, you will need one o2 in the cat, and you will use the one o2 in the collector.
In 00-01, I believe the cat should be around 15-16", and you will use one o2 in the cat, and one in the collector. PM username BSQ, or search for a response to a similar thread. He has a 94 or 95 GSR and had pictures and measurements for his JDM ITR 4-1 header setup. Of course, the measurements will be a little off for the newer GSRs (00-01). You could also ask kteller8 or SMSP to make the cat for you, and they will know the exact dimensions you will need.
Edit - here is that thread: https://honda-tech.com/zerothread?id=1359749
Old Sep 19, 2005 | 07:19 AM
xteg95's Avatar
Default Re: ITR headers on a GSR question. (purplegsr)
You didn't mention but if your GSR is a 00-01 the header is the same length as the ITR/LS. Otherwise I think it's something like 3 inches in length difference.
Old Sep 19, 2005 | 07:21 AM
purplegsr's Avatar
Default Re: ITR headers on a GSR question. (xteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">It all depends on the year GSR you have, also, I am assuming you are talking about the JDM ITR 4-1. The USDM ITR header is the same measurement as any other LS or 00-01 GSR header.
yes I did, but only for the USDM ITR header, I am betting this guy is going with the JDM ITR which will be different for all applications, 94-99 or 00-01.
Old Sep 19, 2005 | 07:22 AM
Nataku's Avatar
'96 GSR. that's what I have.
edit: I just read that post. So it sounds like me being a 96 GSR i need a 12" cat for the 4-1 JDM headers. And it sounds like the ITR cat is 12" so...
I just need to buy the header and cat?
Modified by Nataku at 10:08 AM 9/19/2005
Old Sep 19, 2005 | 07:23 AM
purplegsr's Avatar
Then you need 12 inches, this is BSQ's pic for his 95:
Old Sep 19, 2005 | 07:28 AM
xteg95's Avatar
yes I did, but only for the USDM ITR header, I am betting this guy is going with the JDM ITR which will be different for all applications, 94-99 or 00-01.</TD></TR></TABLE>
I was refering to the OP not you
I didnt read for your first sentence just the rest whoops lol
If you don't want to buy a new cat you can just take it to a muffler shop and get it rewelded for prolly 50 bux (maybe less) or so.
And yeah, is this a USDM or JDM ITR header?
Old Sep 19, 2005 | 09:10 AM
Nataku's Avatar
Yes JDM 4-1 ITR headers is what i'm wanting to buy.
Old Sep 19, 2005 | 09:38 AM
purplegsr's Avatar
[QUOTE=Nataku]So it sounds like me being a 96 GSR i need a 12" cat for the 4-1 JDM headers. And it sounds like the ITR cat is 12" so...
QUOTE]
Yes, you need to buy the header and cat, but the USDM ITR cat is not 12", it is the same as any other 00-01 gsr or 94-01 LS, you want to buy a custom made 12 inch cat with one o2 bung, similar to the pic posted above.
Logan McGrew
Dec 7, 2018 06:17 PM
97tegblk
Jun 3, 2007 02:16 PM
integra_94
Welding / Fabrication
Aug 30, 2004 09:35 PM
slooogsr
Jun 28, 2004 01:04 PM
Nader_D
10
Nov 19, 2003 10:02 AM
