bad piston rings?
Old Sep 18, 2005 | 07:20 PM
drudy's Avatar
Default bad piston rings?
If you have bad piston rings will that make your oil pressure lower than it should be, especially if all four cylinders are bad?
Old Sep 18, 2005 | 08:12 PM
SuzukaBlueAP2's Avatar
Default Re: bad piston rings? (drudy)
Usually you get lower oil pressure when the ring gear in the oil pump is going. How do you know you have lower than normal pressures? Do you have a gauge attached? What are your readings on a warm engine at idle and at 3k rpm?
If your rings are worn, the first thing you'll probably notice is it burning oil. If their worn, they are letting oil past them into the combustion chambers.
Old Sep 19, 2005 | 01:16 AM
Chewie's Avatar
Default Re: bad piston rings? (ScreaminTeg)
you'll start seeing black smoke if your rings are bad.
Old Sep 19, 2005 | 07:31 PM
drudy's Avatar
Default Re: bad piston rings? (Chewie)
yeah i did a compression test on them and two cylinders had 50 and 52 psi and the other two had 75psi.
Its not burning oil though, so could it be burnt valves?
Old Sep 19, 2005 | 08:47 PM
Rev2Eight's Avatar
I thought you'd see blue smoke from bad rings or is that just seals?
Old Sep 19, 2005 | 10:36 PM
drudy's Avatar
Default Re: bad piston rings? (Rev_DC2)
It'd be blueish grey from the oil blow-by.
Old Sep 19, 2005 | 11:16 PM
Chewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drudy &raquo;</TD></TR><TR><TD CLASS="quote">yeah i did a compression test on them and two cylinders had 50 and 52 psi and the other two had 75psi.
Its not burning oil though, so could it be burnt valves?</TD></TR></TABLE>
are those oil pressure readings?
Old Sep 20, 2005 | 12:10 PM
Holy crap. With low compression numbers like that, how does the power feel? Sounds like it's dying to me. You'd have to perform a leakdown test to see if indeed the valves were burnt.
Hmm...it's not burning oil, so it could be your valves. You would see blueish/white smoke like mentioned if you were burning oil.
I'm not sure if there's one posted on here, but i think there are leakdown tests posted on Team-Integra.net. But i think they're on this site too. You should look into doing that.
Old Sep 22, 2005 | 01:42 PM
drudy's Avatar
Those numbers were from a running compression test. The power sux until about 6k when turbo is spooled then pulls alright. I have a feeling this is why it hasnt been running well.
FireInTheHead
Nov 4, 2014 04:15 PM
kihun_cha
Jan 2, 2006 07:45 AM
crxtreme27
Aug 26, 2003 01:25 PM
_Endless_
Jun 14, 2003 08:02 AM
tominos
22
Feb 18, 2003 08:55 PM
