emissions problem need help asap
ok i just intalled a b18a1 in my 93 hb and failed it super bad
hc:1188 limit 220
co:11.71 limit 1.20
co2:5.83
need help moving ta california is it the ecu cuzs i just install it 2 days ago p28 chipped thanx or my o2 sensor
Modified by jdmboi86 at 7:16 PM 9/18/2005
hc:1188 limit 220
co:11.71 limit 1.20
co2:5.83
whoa. thats super bad. haha.
1. try using the correct ECU injectors throttle body etc etc for the motor
2. do u get a CEL (check engine light)? if so then maybe its a sensor
3. did you warm up the car first. like drive around on the freeway for 15 mins
4. cat still any good? maybe somehow raw fuel was dumped into it and it was fried
5. PCV valves EGR etc etc blah blah its stated in ur manual what devices are for emissions
good luck man bump someone with more experience help this guy out
rockthegens
Nov 16, 2005 09:58 AM
