*P30 ECU REDLINING TOO LOW AND NO VTEC*
Old Sep 18, 2005 | 03:54 PM
mintscorpion's Avatar
Default *P30 ECU REDLINING TOO LOW AND NO VTEC*
WHATS UP,
HERE'S MY PROBLEM: I JUST RECENTLY SWAPPED A USDM B16A FROM A 95 DEL SOL VTEC INTO MY 94 HONDA CIVIC EX(THE DEL SOL WAS MINE AND I DID THE SWAP SO EVERYTHING'S LEGIT). WHEN IM DRIVING THERE IS NO VTEC AND THE CAR REDLINES(FUEL CUT OFF) AT AROUND 7OOORPMS. IT SEEMS TO BE STUCK IN COLD START MODE. I'M THINKING THE CAUSE COULD BE THE THERMOSTAT(ORIGINAL) OR THE VTEC CONTROLLER BECAUSE I REPLACED IT WITH A USED ONE RECENTLY. WHAT ELSE COULD CAUSE THIS? PLEASE HELP. MUCH APPRECIATED.
Old Sep 18, 2005 | 04:21 PM
nighttrain33's Avatar
Default Re: *P30 ECU REDLINING TOO LOW AND NO VTEC* (mintscorpion)
I don't know the actual cause of the problem, but I know that the thermostat wouldn't be the cause unless you never get up to N.O.T. Before I replaced my thermostat, it took a while to get there, but once I did, everything worked fine.
-Shane
Old Sep 18, 2005 | 05:28 PM
v4lu3s's Avatar
RTFM
try removing the vtec controller so you have stock wiring and see if it works.
Old Sep 18, 2005 | 07:33 PM
bump, help please
Old Sep 18, 2005 | 08:06 PM
Relic1's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">try removing the vtec controller so you have stock wiring and see if it works.</TD></TR></TABLE>
good advice.
do you have a CEL? (check engine light)
Old Sep 19, 2005 | 05:29 PM
Default Re: (Relic1)
there is no check engine light.
Old Sep 19, 2005 | 05:41 PM
v4lu3s's Avatar
RTFM
have you removed the vtec controller and restored factory wiring yet?
Old Oct 6, 2005 | 08:38 PM
crazi92hb's Avatar
yeah it definitly sounds like a vtec controller problem.
acidburn2k2
Dec 10, 2005 12:48 PM
mintscorpion
Sep 23, 2005 07:20 PM
H22edAccord
Apr 19, 2004 07:25 AM
delsolrmp
Nov 15, 2003 07:46 AM
CRVTEC96
Mar 3, 2003 02:50 AM
