'03 Civic / Code 113 for Engine Maint light (where is the AIT Sensor?) Question.
Background:
This is apparently the "High input" code, which usually means that the thing is disconnected, or otherwise not functioning.
I looked in the air filter housing for it, and off to the right, there's something which looks exactly like a sensor (it's plugged in from the outside, and has a little shiny black nipple that sticks inside). Is this it? It doesn't look messed up. Anything I should know about replacing it, or driving around on a broken one?
Further discoveries: The hams at Jiffy Lube drilled out one of the air filter housing screws, and stripped two others, when I consented to allowing them to change the air filter. Note to self: Do all maintenance work myself.
john1233567
Oct 22, 2015 03:05 PM
hondabinge
Apr 12, 2011 02:13 PM
