Quick Question!!!
On my oil pan the plug for draining the oil stripped the threading on the oil pan. I was wondering how much does it cost to re-tap it or (re-thread) it. I did everything normal, but when I got to my friends house it was leaking oil. so I thought it was loose, so I tightened it. and it goes tight, then goes loose again, same thing repeatedly.
ouch... you MAY or may not get away with a shirt term quick fix by wrappign the plug with some thin material and then screwing it back on... very temporary. usually tapping or helicoil can be from 30 to 100, you could get you own coil kit and try and do it
**** that, ill leave it to the pro's.
I called a guy and he didnt sound sure he was like... Uhhhh for re-threading we use in insert and we have to dismantle and take out ur motor. so your looking at an easy over 200. My friend was telling me he was bullshitting and didnt know what he was talking about, which I hope is true.
you sound like you know what your talking about but I have to wait till monday. All shops are closed.
I changed my oil so I could ride today with my friends to the LA fair... now I cant ride at all.
an insert IS a heilcoil...soem can do it in the bike, but more than likely the case has to be accessable... so if the ehgine comes out $200 is not bad. most of that is labor... hence doing it yourself
its real easy to get access to it. if they put it on their lift, its right under the bike, real easy to get to. i hope they dont have to remove the engine.
Unless you want metal shavings in your oil pan, personally I'd drop the pan/motor before trying to insert a helicoil, or at least flush it out really good before starting the engine.
This is why they make torque wrenches.
$100 Craftsman torque wrench > $200+ in repairs for stripped threads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">.
$100 Craftsman torque wrench > $200+ in repairs for stripped threads.</TD></TR></TABLE>
Hahahahaha
Hahahahaha
No really, one of the best tools I own, a Digitork torque wrench by Craftsmen, ran me about $100. Does 5-80 ft/lbs and its easy as hell to adjust.
Do I use it all the time? Nope. But when I'm tightening down bolts is it worth having to know that I'm not going to be stripping stuff out? Absolutely.
Use them on everything, saves in the long run. Isn't the drain in the crank cover?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .paul »</TD></TR><TR><TD CLASS="quote">same thing happened to my gixxer, the oilpan stripped.. took it to a gas station mechanic I know - he re-threaded it and doesnt leak any oil or anything </TD></TR></TABLE>
that makes me feel so much better knowing that. how much did you pay?
I just called 2 places and they charge $210 for the heilcoil. Why are they charging so much. thats not even including the service charges... can someone help me out on a place in orange county that can do it for cheaper. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">This is why they make torque wrenches.</TD></TR></TABLE>
I've stripped Honda pans using torque wrenches.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 »</TD></TR><TR><TD CLASS="quote">
doh! I dont feel so comfortable doing my own work. I decided ima take my **** in instead of trying and learning for myself.
</TD></TR></TABLE>doh! I dont feel so comfortable doing my own work. I decided ima take my **** in instead of trying and learning for myself.
yeah... unfortunately that is true on the b series
</TD></TR></TABLE>yeah... unfortunately that is true on the b series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My Gixxer 750 »</TD></TR><TR><TD CLASS="quote">I just called 2 places and they charge $210 for the heilcoil. Why are they charging so much. thats not even including the service charges... can someone help me out on a place in orange county that can do it for cheaper. Thanks</TD></TR></TABLE>
Buy your own helicoil kit?
whytetygerwolf
18
May 27, 2014 05:56 PM
next157
Sep 2, 2004 12:43 AM
