Transmision problem
Ok i went out drag racing today for the first time. Did my first pull and felt like i was breaking loose all the way down the track. I was goin for another run and started my car and could not get it in gear. the same thing happend 3 weeks ago changed fluid and master cylinder. Problem went away. This time it didnt i put the car in gear and then started the car and was able to shift OK. The shifting got worse as i drove home to the point where the clutch is not dissengaging now. But when car is off and clutch is in i can shift through the gears. The clutch i have in there is supposed to be indestructable(i have 300 wheel horse) I was told it could be the slave cylinder and the clutch fork? Please help advice would be greatly appreciated as im gonna put the tranny myself. thx
the fluid is a little low but its not under the add line last i checked but if the slave is leaking would it also be sucking in air ?
Honduh Uhcord
Oct 15, 2007 08:29 PM
95civicracer
Aug 3, 2003 04:58 PM
