Ignition output signal
Old Sep 17, 2005 | 01:38 PM
drwsrex's Avatar
Default Ignition output signal
Since the search isn't working I thought I would post my question. I have a b16a in a crx and am throwing a code 15 (ignition output signal). My car cranks, but won't start. What are the possible causes and how do I fix this problem? Thanks.
Old Sep 17, 2005 | 01:59 PM
v4lu3s's Avatar
RTFM
try a new coil or new ignitor.
Old Sep 18, 2005 | 08:23 PM
GORDO1473's Avatar
Default Re: Ignition output signal (drwsrex)
i have the same problem going on with a b 16 swap in a hatch and if i find the cause before you do i willl let you know what it is and i wounld appreciate the same thing my e-mail is gordo1473@aol.com
Old Sep 19, 2005 | 06:27 AM
JimBlake's Avatar
Default Re: Ignition output signal (GORDO1473)
Code 15 refers to the circuit FROM the ECU which tells the ignitor to fire the coil. I don't think a bad coil can cause that. Bad ignitor, or bad wiring between ECU & ignitor. You can look for loose or corroded wiring connected to the ignitor. Loose/dirty plug at the distributor? Stuff like that.
Old Sep 19, 2005 | 12:16 PM
GORDO1473's Avatar
Default Re: Ignition output signal (JimBlake)
ok i have replaced the ignition control module and the same thing is happening.we have tracked it down to the injectors are not getting power to them.i dont know if this is a telltale sign of anything but anyones help is appreciated
Old Sep 19, 2005 | 12:31 PM
JimBlake's Avatar
That sounds strange. I thought injectors having no power should throw code 16, not 15.
Old Sep 19, 2005 | 03:30 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">That sounds strange. I thought injectors having no power should throw code 16, not 15.</TD></TR></TABLE>
That's correct, sounds like there are multiple problems. Has he checked his fuses?
Old Sep 19, 2005 | 03:43 PM
GORDO1473's Avatar
Default Re: Ignition output signal (Chiovnidca)
we have checked all fuses, relays all i can guess is there is either a ground issueor the like.i get fuel to the rail and nothing through the injectors. injectors are new.
Old Sep 19, 2005 | 03:55 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drwsrex &raquo;</TD></TR><TR><TD CLASS="quote"> I have a b16a in a crx and am throwing a code 15 (ignition output signal).</TD></TR></TABLE>
Do you have battery voltage at the blk/yel wire on the distributor? (with the key on)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GORDO1473 &raquo;</TD></TR><TR><TD CLASS="quote"> all i can guess is there is either a ground issueor the like.</TD></TR></TABLE>
Is the ground wire bolted to the t-stat housing clean and tight?
Old Sep 19, 2005 | 05:43 PM
v4lu3s's Avatar
RTFM
i have seen SOME cases wehre a bad ecu can cause a code 15, but most often at work i see code 15 caused by the coil beind bad, ESPECIALLY on internal coil setups. btw i work at a honda only repair shop.
Old Sep 19, 2005 | 06:12 PM
GORDO1473's Avatar
not to sound ignorant but what is the t-stat housing?
Old Sep 20, 2005 | 03:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GORDO1473 &raquo;</TD></TR><TR><TD CLASS="quote">not to sound ignorant but what is the t-stat housing?</TD></TR></TABLE>
Thermostat
slammedvtec
Apr 17, 2008 02:17 PM
Dan_UK
Feb 6, 2006 04:19 PM
jonathancrx
Mar 19, 2005 01:33 AM
djnikko
Mar 1, 2004 09:12 AM
