Shifter linkage
Old Sep 17, 2005 | 11:57 AM
slowcivicSI's Avatar
Default Shifter linkage
I was wondering is there is any way of eliminating the looseness that develops with time on the shifter. How can I make the shifter as tight or tighter than new. What parts would I need to fix this problem.
Old Sep 17, 2005 | 12:01 PM
2lua's Avatar
Default Re: Shifter linkage (slowcivicSI)
get engery suspension busing for the tranny shift linkage at auto zone for 11-13 bucks.
honda trans bush = part # 16.1101R
Old Sep 17, 2005 | 12:38 PM
VX's Avatar
VX
Default Re: Shifter linkage (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">get engery suspension busing for the tranny shift linkage at auto zone for 11-13 bucks.
honda trans bush = part # 16.1101R</TD></TR></TABLE>
Depending on the year Civic you have. The part # for the ES Bushing set mentioned above will not fit all applications. I know b/c the 16.1101R shifter bushings didn't fit into my EH2 shift linkage.
Taken from the ES website: http://energysuspension.com/pages/hon1.html
Civics (1984-87) Manual Transmission Shifter Stabilizer Bushing Set: 16.1101
Civics (1988-00) Manual Transmission Shifter Stabilizer Bushing Set: 16.1102
And here's a how-to on the install:
https://honda-tech.com/zerothread?id=1001924
https://honda-tech.com/zerothread?id=1002429
Old Sep 17, 2005 | 05:20 PM
cknisley's Avatar
For movement when you press the gas, replace the rubber bushing where the torque rod attaches to the transaxle. For side-to-side looseness, replace the bushings at the shifter.
Any Honda parts counter will have these in stock.
Old Sep 17, 2005 | 05:31 PM
.Ry's Avatar
.Ry
Default Re: Shifter linkage (cknisley)
Get the Energy Suspension shifter bushings. I had the same problem and the new bushings fixed it 100%. I got it at summitracing.com. Not sure if you can get them at autozone though. Do a search for shifter bushings. There are two articles on how to change them by a member on here.
civicsi0721
Feb 25, 2009 07:14 PM
tommyleeruiz
Jul 20, 2007 04:49 PM
hondaPINK
17
May 17, 2006 06:09 PM
crxman00
12
Apr 5, 2003 09:26 AM
