F***ing Axle!!!!! Need Help ASAP
Old Sep 17, 2005 | 10:33 AM
rex_racer728's Avatar
Default F***ing Axle!!!!! Need Help ASAP
So here is what i got. 99-01 Civic Si Tranny hooked to a b20z and a gsr head all in a 1994 Acura Integra LS W/ ABS. So anyways I bought GSR axles because someone told me they would last longer so why not but now every week or so the axle pops out the transmission on the passenger side. Then throws tranny fluid everywhere. Then I have to get underneath it and fix it but it keeps leaving me stranded. Also it feels like there is some up and down play when the axle is in the tranny. And its all the way in. I used a block of wood on the hub side and tapped it in and wasnt coming out when i put them in and its just all of a sudden out of nowhere they pop out. What the hell could be the problem. Do i just get LS axles or B16 axles or what. Help me out. Its the only car I have and cant just keep getting stranded. Thanks
Old Sep 17, 2005 | 10:49 AM
the_23rd_letter's Avatar
Default Re: F***ing Axle!!!!! Need Help ASAP (rex_racer728)
i have no idea if this would cause the problem but the first thing that came to mind was the cir-clip on the end of the splines. is it on there?
Old Sep 17, 2005 | 11:18 AM
agrn93ls's Avatar
Default Re: F***ing Axle!!!!! Need Help ASAP (the_23rd_letter)
i agree about the c-clip that is what actually holds the axle in.
Old Sep 17, 2005 | 11:24 AM
Yeah the c-clip is on there. Someone told me the diff is going out but why would it stay in for awhile and then come out. Its pissing me off so bad. What to do!!!
Old Sep 17, 2005 | 04:06 PM
its possible the diff is messed up... are the splines on the driveaxles chewed? or the splines on the diff chewed? if so it could just be that its a loose fit.
Old Sep 17, 2005 | 04:27 PM
lzylst's Avatar
Are they OE axles ?
Old Sep 17, 2005 | 08:39 PM
locash's Avatar
If the differential is moving up and down when the axle is in there, I'd say that your differential bearings are shot..
Besides, LS and GSR axles are the same thing for 94-01.
Old Sep 18, 2005 | 12:52 PM
agrn93ls's Avatar
Default Re: F***ing Axle!!!!! Need Help ASAP (locash)
^^^^^^^^^^ but dont be mislead if you grab ahold of your CV joint on the axle, at the transmission and move it up and down it is normal so if you check for up and down movement make sure you see what is moving the joint does fit loosely in the diff and this is NORMAL but how loose is hard to explain, i know by feel from messing with and checking axle's.
as far as your problem, does it seem to be the proper length??? are they OE axle's?? if they are from auto crap or somewhere else take it back and try another hell if its new from the dealer tell them its junk and get another and try it, make sure your motor mounts arent really screwed and the engine is moving excessively
try another c-clip see if that works
has your car had any major front end damage where its possible the length from tranny to wheel could be off???? i know it's random but so is your problem
are the motor mounts proper for the setup??
as far as your set up and axle combo i dont see why there would be a problem i would think you could use any B series combo and use those axle's, well any late model combo's
jdmNit
Apr 6, 2011 08:18 AM
rex_racer728
Sep 24, 2005 02:46 PM
HatchBox
13
Dec 3, 2003 07:27 PM
7PSiEF9ZC
Aug 15, 2003 02:23 PM
SikofFalln
Aug 7, 2003 02:05 PM
