high mileage engine.....
Old Feb 28, 2002 | 10:36 AM
xXsarcasmXx's Avatar
Default high mileage engine.....
if I was going to build up an engine like basically everything rod/pistons/etc... would it matter if the engine was high mileage before????
please help I need a quick answer
Old Feb 28, 2002 | 10:56 AM
Spade's Avatar
Default Re: high mileage engine..... (xXsarcasmXx)
Nope. Make sure when you say rebuild you are rebuilding everything including bearings.
Old Feb 28, 2002 | 10:59 AM
TurboMiata's Avatar
Default Re: high mileage engine..... (Spade)
For all none moving parts, no mileage doesnt matter. A block with 10k on it, and a block w/ 250k on it are about the same unless something catastrophic has happened. The same isnt true for the parts your talking about replaceing though. However if your building an engine I would expect you to use all new bearings, and internals anyway.....
Old Feb 28, 2002 | 11:10 AM
Default Re: high mileage engine..... (TurboMiata)
bearings/seals/everything........thanks guys....I thought it'd be ok but wanted to make sure....still a newbie at this
Old Feb 28, 2002 | 11:20 AM
TurboMiata's Avatar
Make sure you have the block cleaned btw. "hot tanked" I believe is the term. Cleans out all the oil and coolant passage ways which might have buildup in them from over the years...
Old Feb 28, 2002 | 08:19 PM
cool cool......thanks
Old Feb 28, 2002 | 08:42 PM
rainforest's Avatar
one thing to think about is the crank. check the journals for groves or scratches. thats basiclly the only moving part that will stay in your motor iam figuring. some non moving parts to look at is the cylinder head for straightness, the blocks deck, the cylinder walls, and the rest is the little stuff.
chikin pickle
Nov 10, 2010 03:39 PM
kte324
Oct 28, 2010 08:38 AM
IBriaIN
Mar 2, 2010 07:28 PM
92boostedgsr
Jun 22, 2007 02:54 PM
Tomservo
Jun 11, 2004 06:17 AM
