Problems with Cusco oil catch installation on gsr
Old Sep 16, 2005 | 09:02 PM
sp00led's Avatar
Default Problems with Cusco oil catch installation on gsr
I'm trying to install the hoses for the catch can and ran into a problem. The hoses are to big in diameter to fit on the pcv valve. Does someone make an adpater or a nipple that will allow it to fit?
I haven't even looked at the spot on the manifold. It's way up under everything and looks like its gonna take some small hands to get to. I think since it connects using the same size hose as pcv valve that the new hose will be to big for it to.
Surely someone has done this install before me, someone throw me a hint.
Old Sep 17, 2005 | 01:07 AM
Deluzional's Avatar
Default Re: Problems with Cusco oil catch installation on gsr (sp00led)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to install the hoses for the catch can and ran into a problem. The hoses are to big in diameter to fit on the pcv valve.
have you tried to use some clamps to tighten them? if not take a short piece of your original hose and try to jam it into the bigger diamater hose so its a nice perfect fit, then jam that on your pcv valve
Old Sep 17, 2005 | 01:33 PM
sp00led's Avatar
Default Re: Problems with Cusco oil catch installation on gsr (Deluzional)
Thanks for the idea. Anyone else?
Old Dec 11, 2005 | 07:33 PM
sp00led's Avatar
Cusco sells two different sizes. If you have a b-series make sure you don't get the 15mm kit.
Old Oct 31, 2008 | 10:09 AM
tnez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led &raquo;</TD></TR><TR><TD CLASS="quote">Cusco sells two different sizes. If you have a b-series make sure you don't get the 15mm kit. </TD></TR></TABLE>
correct!!! use the 9mm version, the nipples are a PERFECT FIT!
I just went to OSH and got the nylon/kevlar hoses that fit on the can/nipples and they plugged right into the PCV with ease
EHracer06
12
May 27, 2009 09:31 AM
dreamreaperx
Jul 17, 2008 08:49 PM
HamiltonRex
Nov 18, 2004 02:18 PM
graphic
Oct 9, 2003 08:36 PM
