Clicking at idle, only when the car is warm.
LSvtec w/ endyn rollerwaves and eagles. The block was milled 25 thousands and the pistons stick out of the deck 4-5 thousandths. I'm using a thick headgasket.
Not when i start the car, or let it warm up. but after its all warm i start to hear one click coming from the head. If you get down and put your ear next to it its either coming from above the #1 cylinder or down by the pullies. Its pretty loud and very consistent. Once i start to accelerate, i can no longer hear the noise.
I have checked my valve clearances 3times, and every time they are perfect.
is it a loud clicking or a faint clicking? what size injectors do you have? A friend of mine had the same problem but it turned out to be his injectors where clicking really loud
its really ******* loud. i'll go move the injectors around and see if that changes anything. (where the sound is coming from
stock injectors. still waiting on the boost
)stock injectors. still waiting on the boost
moving them around wont do much.... but if you take a long screw driver and place the metal end on the injector and put your ear on the plastic handle you will be able to tell if its the injectors
