pr4?
Old Sep 16, 2005 | 09:07 AM
superbeastcrx's Avatar
Default pr4?
does a pr4 have a rev limiter? what rpm does it limit me to? is it possible to have it taken out for resonable?
Thanks j.d.
Old Sep 16, 2005 | 09:13 AM
EP3_05's Avatar
Default Re: pr4? (superbeastcrx)
Yes the ecu has a revlimiter which I think is around 7200....not sure though. Yes when you have the ecu chipped you can specify to take it out. Only good reason to take it out is when you are making power above the limiter
Old Sep 16, 2005 | 09:15 AM
drdisco69's Avatar
Yes, all stock ecus have a rev limiter. The PR4 is from the Integra LS, so the limiter is around 7400rpm I think, not 100% sure. Removing the rev limiter isn't a great idea, as one missed shift can be the end of your motor. It's better to just raise it up so you have a safety net. Prices vary, but it comes down to you'll need to have the ecu chipped and a new rom made and put in.
Old Sep 16, 2005 | 11:27 AM
Default Re: pr4? (drdisco69)
rom? any good place to have my ecu chipped.
Old Sep 16, 2005 | 11:37 AM
drdisco69's Avatar
I would of course have to recommend myself , but there are others availible, you're free to shop around.
Old Sep 17, 2005 | 05:36 AM
how much would you charge?
Old Sep 17, 2005 | 06:28 AM
davens's Avatar
Redline was 6500.
I don't know what the spec rev limit is exactly but mine kicks in around 6900-7000 rpm.
Old Sep 17, 2005 | 06:59 AM
Default Re: (davens)
thanks for the information.
Old Sep 17, 2005 | 07:20 AM
zccr-xsi's Avatar
lmao wrong i have a 91 pr4 and i tried to run my zc and it had rev limter of 6800
stiffymeister28
Jun 10, 2011 08:22 AM
tenchi r
Mar 6, 2010 10:45 AM
AkEuro_R
Apr 27, 2004 04:00 PM
