p72 vs. p28 why did you choose one or the other (when chipping)?
Old Feb 28, 2002 | 08:04 AM
Black R's Avatar
25 Year Member
Default p72 vs. p28 why did you choose one or the other (when chipping)?
Old Feb 28, 2002 | 08:07 AM
Austin's Avatar
Default Re: p72 vs. p28 why did you choose one or the other (when chipping)? (Black R)
I getting to dislike the Flood Protection...
P28, it's what I have...
Old Feb 28, 2002 | 08:08 AM
Willard's Avatar
P72 = knock sensor...
Will
Old Feb 28, 2002 | 08:12 AM
sloppy_seconds's Avatar
Banned
Default Re: p72 vs. p28 why did you choose one or the other (Willard)
true will, but when they chip the P72, doesn't the program disengage the knock sensor anyway?
--justin
Old Feb 28, 2002 | 08:13 AM
Willard's Avatar
Default Re: p72 vs. p28 why did you choose one or the other (slowasscx)
not sure...
I would hope the knock sesnor is still working... what gain would be had from turning it off?
Will
[Modified by Willard, 12:15 PM 2/28/2002]
Austin's Avatar
--justin
Nope, it's retained...I know that there are a couple of good threads around here about knock sensors and hondata...just don't have the time to wade through all the topics, while pretending to work
Old Feb 28, 2002 | 08:16 AM
sgT's Avatar
sgT
Default Re: p72 vs. p28 why did you choose one or the other (Austin)
ECUs equipped with knock control disable the sensor above 5000rpm due
to excess noise. Honestly the cost of a P30/P61/P72 ECU isnt worth it when
a P28 does the job just as well for less than half the cost.
And the knock control under 5000rpm is crap when compared to something such
as a J&S.
Old Feb 28, 2002 | 08:18 AM
MPH's Avatar
MPH
New User
"while pretending to work"
I have a p-28 because it seems to be easier to find.
Old Feb 28, 2002 | 08:24 AM
Mike K's Avatar
Default Re: p72 vs. p28 why did you choose one or the other (MPH)
Regarding Hondata, I heard the P72 is capable of more "fine tuning" because it is 15x15 maps compared to 10x10 or 12x12 of the P28.
Any truth to this?
Looose_R's Avatar
p28, much much cheaper. does the same thing
Old Feb 28, 2002 | 09:18 AM
sgT's Avatar
sgT
Default Re: p72 vs. p28 why did you choose one or the other (Mike K)
Any truth to this?
No.
Old Feb 28, 2002 | 09:20 AM
gsr98vtec's Avatar
Default Re: p72 vs. p28 why did you choose one or the other (sgT)
isnt the p72 a gsr ecu that controls the dual butterflies? dont type r's have single butterfly on the throttle body? thats why i thought you wanted a p28 over a p72
Old Feb 28, 2002 | 09:25 AM
C-speed's Avatar
Default Re: p72 vs. p28 why did you choose one or the other (gsr98vtec)
p72 has the IAB control, yes - but having it connected or not isn't required. The ITR doesn't have IAB's therefore the ecu doesn't control them. The IAB is on the GSR intake manifold.. not on the throttle body.
There's only 2 reasons distinguishing the difference between the p28 and the p72:
p28 = cheaper
p72 = knock control
Thats it.
Old Feb 28, 2002 | 10:15 AM
FSTASNTZ's Avatar
P-28, easy to find, readily available, and due to that is less than half the price of a P72 in most cases.
Knock sensor would be fine, but being disabled at 5000+, does not seem worth it to me...
Jason
Old Feb 28, 2002 | 02:50 PM
EJK's Avatar
EJK
New User
excuse the ignorance.. but what exactly does the knock sensor do?
ohsnapzafingcu
Oct 21, 2007 09:21 AM
SHG_EasyE
Jan 22, 2006 11:26 AM
Jmunk
Feb 23, 2005 04:54 AM
eda6
Oct 8, 2004 03:54 AM
7rrivera7
Nov 8, 2002 10:40 AM
