Honda S2000 Honda S2000
*** 2 times damage in my crankshaft bearings (rods bearings) WHY?
Old Sep 15, 2005 | 10:15 PM
u_tal's Avatar
Default *** 2 times damage in my crankshaft bearings (rods bearings) WHY?
Hello guys!
I have a big big problem!:
I upgrade my S2k i installed turbo with all the good parts (pistons, rods ect..)
But it's already 2 times damage in my crankshaft bearings (rods bearings) WHY?
Is somebody have a clue?
my S2000 year: 2002
Thank you
Udi
ISRAEL
Old Sep 16, 2005 | 07:09 AM
Mr. Bagel's Avatar
Default Re: *** 2 times damage in my crankshaft bearings (rods bearings) WHY? (u_tal)
There is a bit more to look into.
What about the bearings are failing? Are you spinning them? Or are they scorched, broken?
Also, a bit more details regarding the pistons, rods, etc. Compression ratio and amount of boost from the turbo?
Old Sep 16, 2005 | 08:44 AM
devnull's Avatar
also what kind of oil are you using? have you done any measurements for the crank or rod bearing (plastistrip is your friend).
Did you balance the rods and pistons? did you rebalance the crank with the new rods and pistons set?
Old Sep 16, 2005 | 09:24 AM
u_tal's Avatar
I heared that there is problem with the banjo oil bolts that from year 2002 they change it to 4 holes... somebody know something about it?
Old Sep 16, 2005 | 11:32 AM
devnull's Avatar
Banjo bolt is 1 hole only. I can't image a 4 hole banjo bolt.
Do you mean rod bearing? The upper rod bearing bolt might have 4 holes for oil passage. Don't know exactly how many holes though.
Old Sep 17, 2005 | 02:59 AM
u_tal's Avatar
Default Re: (badboypolar2)
Yes i mean the rods bolts... co's i have only 2 holes and i eared that they change it to 4 holes....
Do you know something about that?
Old Sep 17, 2005 | 08:51 AM
earl's Avatar
Default Re: (u_tal)
The banjo bolts have nothing to do with the rods. A late model oil squirter bolt now has 4 holes in it rather than 2. They can be installed in place of the old ones. Changing these bolt will not fix your rod bearing problem.
Not sure why your rod bearings failed the first time but if you did nothing to the crank and just replaced the bearings, they will definitely keep failing over and over again. Something is wrong with your crank or aftermarket rod. You may need to swap out your crank and have the big end of your rods rebuilt/resized to fix the problems. It is NOT a problem with bad bearings.
Old Sep 17, 2005 | 04:35 PM
u_tal's Avatar
Is somebody can offer me set of rods for my turbo S2k?
Old Sep 19, 2005 | 02:08 PM
Oyvind Ryeng's Avatar
Is it even tuned?
Old Sep 19, 2005 | 02:36 PM
u_tal's Avatar
Default Re: *** 2 times damage in my crankshaft bearings (Oyvind Ryeng)
Sure! aem ems
Old Sep 19, 2005 | 03:24 PM
JDM knowledge's Avatar
Default Re: *** 2 times damage in my crankshaft bearings (u_tal)
damn that sucks i hope you get it fixed. Bump for an answer.
Old Sep 19, 2005 | 05:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oyvind Ryeng &raquo;</TD></TR><TR><TD CLASS="quote">Is it even tuned?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u_tal &raquo;</TD></TR><TR><TD CLASS="quote">Sure! aem ems </TD></TR></TABLE>
Sure shut me up. I have nothing further.
EDIT: A thaught occurs. What were the rod bearing clearances?
Old Sep 19, 2005 | 05:29 PM
fknfast's Avatar
Old Sep 19, 2005 | 05:34 PM
earl's Avatar
Default Re: (u_tal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u_tal &raquo;</TD></TR><TR><TD CLASS="quote">Is somebody can offer me set of rods for my turbo S2k?</TD></TR></TABLE> Stock rods?
Old Sep 20, 2005 | 08:52 AM
u_tal's Avatar
I got rods! but now i need 1 size over rods and main bearings....... anybody? here we don't have!
Old Sep 20, 2005 | 09:34 AM
blkturbos2k's Avatar
Default Re: (u_tal)
Order them??? You can ship stuff everywhere
Old Sep 21, 2005 | 03:40 PM
earl's Avatar
Default Re: (u_tal)
I don't know of any company making oversized bearings for the S2000 yet. Let me know if you find them.
Old Sep 22, 2005 | 01:40 PM
WhiteSol's Avatar
Default Re: (earl)
Detonation is my first thought.. it shows up on the rod bearings often. Do you have a recent log of a 3rd gear pull?
Old Sep 28, 2005 | 07:09 AM
u_tal's Avatar
Default Re: (WhiteSol)
No i don't have any log.... still looking for crank...
Old Sep 28, 2005 | 01:21 PM
onebadld's Avatar
Default Re: (u_tal)
i have a crank and head for sale 600 for all of it includes cams block and crank bare
Old Sep 28, 2005 | 03:40 PM
u_tal's Avatar
Do you have an Email ?
orioncivic
Aug 15, 2012 04:36 PM
hybridmiklo
Jan 27, 2012 05:40 PM
GoldLudeRay
Sep 13, 2008 03:51 AM
oxygen241
Nov 13, 2004 10:52 AM
Sh4rky
May 24, 2002 08:37 PM
