engine break in process---smoke?
Old Sep 15, 2005 | 09:48 PM
sir2sol's Avatar
Default engine break in process---smoke?
i just rebuilt my b16a and been having problem after problem with it. newest one is that is smokes pretty badly. the engine has plenty of power and runs really nice, only problem it smokes like a train. i've heard that the engine will probably smoke for a little while til the rings seat, is this true, and if so for how long will they smoke? i do believe that the engine is still out of time and it still needs tuned properly. would these factor the smoking somewhere? i'm in the process of getting a set of adjustable cam gears and plan on getting it tuned later this fall. any thoughts?
Old Sep 15, 2005 | 10:04 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: engine break in process---smoke? (sir2sol)
did you install the rings correctly?
Old Sep 15, 2005 | 10:11 PM
sir2sol's Avatar
Default Re: engine break in process---smoke? (PURPLETERROR)
pretty sure, i followed the instructions of the service manuel that i had, gapped them properly and used lube to press them into the block.
Old Sep 16, 2005 | 09:19 AM
sir2sol's Avatar
bump
Old Sep 16, 2005 | 09:21 AM
drdisco69's Avatar
It shouldn't be smoking a lot, just a little haze when you get on it hard. If it's a lot of blue smoke, or any white smoke, something might be wrong. If it's black, like it's running rich, you might be washing down the cylinder walls, and causing ring and piston damage.
Old Sep 16, 2005 | 10:06 AM
sir2sol's Avatar
Default Re: engine break in process---smoke? (drdisco69)
i was planning on checking the compression today and hopefully find something out from that. i know that the compression should be higher, but how much higher with .25 over ctr pistons?
Old Sep 17, 2005 | 01:51 PM
sir2sol's Avatar
checked the compression today and everything seems ok from the rings side of things, i got 190-195 across all four cyclinders with no leaking off. i'm pretty happy with this but still have smoke. i was wondering if it could be a leak in my head gaskett, but there's no coolant in my oil or vice versa. i hope with the new cam gears and a nice tunning everything will work out.
Old Sep 18, 2005 | 03:43 PM
sir2sol's Avatar
still have smoke, haven't gotten it tunned yet , but i think the situation is worse than i thought. the car run great, no problems anywhere even has all the power i was hoping for after the rebuild. but the damn thing still smokes! i drive down the street and it's like i have my own smoke screen, sometimes blue, sometimes grayish white. could not having an ecu tunned for the higher compression pistons be causing this? HELP!
Old Sep 18, 2005 | 03:58 PM
mmuller's Avatar
Mad Scientist
its not coolant isnt it?
did you do the cap of oil in the cyl. thing when doing the compression test?
Old Sep 18, 2005 | 05:58 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir2sol &raquo;</TD></TR><TR><TD CLASS="quote">could not having an ecu tunned for the higher compression pistons be causing this?</TD></TR></TABLE>
Um, yes! What did you replace in the motor, what are you currently running?? Detonation due to not enough fuel or too much timing can cause the pistons to contact the cylinder walls and grind away the rings and pistons, amongst other things...
Old Sep 19, 2005 | 11:02 AM
sir2sol's Avatar
i replaced the old p30 pistons with new ctr overbore pistons. and of course i changed the piston rings and wrist pins as well. other than that the bottom end was pretty much assembled using oem replacement parts. i did have the head rebuilt earlier this year.
Old Sep 19, 2005 | 11:03 AM
sir2sol's Avatar
oh yea and when i did the compression test i didn't put oil in the cyclinder. i always thought that would give a false result?
Old Sep 19, 2005 | 11:04 AM
Tech6023's Avatar
190-195 isnt that good, I would think it should be 220+, you should try a leak down test
Old Sep 19, 2005 | 12:53 PM
sir2sol's Avatar
Default Re: engine break in process---smoke? (Tech6023)
is it so much the numbers that are important for a compression check, or just the fact that the numbers are within say 15 psi either way?
i just checked my compression numbers again with the car up to op. temp. and i got 215,215,225,215 respectively. so they did go up quite a bit.
Modified by sir2sol at 2:11 PM 9/19/2005
Old Sep 19, 2005 | 03:05 PM
what kind of break in oil are you using?
Old Sep 19, 2005 | 07:37 PM
dragaholic's Avatar
valve seals?
Old Sep 19, 2005 | 09:07 PM
sir2sol's Avatar
Default Re: (dragaholic)
i'm using pretty much the cheapest crap oil i could find in 5w30. i don't think it's valve seals because it doesn't do it at start up or idle, just when driving plus the head was rebuilt by a pro just this spring. one of my buddies followed me tonight and he said it looked and smelled as if maybe it was unburnt fuel, too light and whispy to be oil. also i just relized an important part of my rebuild that might be a bullet in the chamber, i'm using a oem replacemnt headgasket. could that cause any type of screw ups?
Old Sep 19, 2005 | 09:20 PM
sicsixone's Avatar
Default Re: (sir2sol)
tech6023 said it,you need to do a leak down test.you should not have more that 15% leak down on each cylinder.it sounds like there is something wrong with your piston rings.did you have any machine work done on the block before you changed the pistons and ring's.please tell me you didnt install a block guard.
Old Sep 19, 2005 | 09:23 PM
sicsixone's Avatar
Default Re: (jonsswapshop)
me myself i dont beleave in that whole thing about breaking rings in.if all of your dimension are corect than there shouldnt be anything to break in.
Old Sep 19, 2005 | 09:26 PM
sir2sol's Avatar
haven't had a chance to do a leakdown test yet. yes i did have a machine shop bore the cyclinder walls and i didn't install a block guard.
Old Sep 21, 2005 | 06:35 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonsswapshop &raquo;</TD></TR><TR><TD CLASS="quote">you should not have more that 15% leak down on each cylinder</TD></TR></TABLE>
It better be a whole lot less than 15%...
Old Sep 21, 2005 | 09:12 AM
mmuller's Avatar
Mad Scientist
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">It better be a whole lot less than 15%...</TD></TR></TABLE>
damn right skippie
the cap of oil is to see if #'s jump up dramatically; kinda rough estimate to see if rings are leaking.
as everyone is saying leakdown test will pinpoint whats going on...the rest is internet guessing..
Old Sep 21, 2005 | 08:04 PM
MenaceL.A.671's Avatar
Default Re: (mmuller)
you might be running rich.. but anyway do you have a chipped ecu.. it might be the cause.. cuz i have the same problem.. but only when i turn on my a.c. then thats when i spit out smoke..
Old Sep 21, 2005 | 09:15 PM
sir2sol's Avatar
Default Re: (m2slsvtec)
i adjusted the timing on the distributor today and i noticed it affected the smoke a little and that was at like a degree's difference. i'm pretty sure that it is the fact that i've still got a lot of issues address with building this motor. i read a posting and i've pretty much got to upgrade everything to make things right. i'm pretty much going to have to upgrade my whole fuel system to feed these new pistons right. and an upgraded ecu of some type, probably going to go with hondata on this one. anyone think of anything else i might be overlooking?
Old Sep 23, 2005 | 08:46 AM
drdisco69's Avatar
The only fuel system upgrade you'll need is injectors, 310s should work, but 440s are cheap and easy to find from the DSM guys. The pump and fuel rail are good for way more power than us NA guys can hope for. As far as engine management: http://www.pgmfi.org
Brembomaster
Engine Machining & Assembly
15
Apr 9, 2019 10:25 AM
90honduh
21
Feb 15, 2010 07:06 AM
u2civic1
Sep 11, 2003 01:50 PM
turbopanda
Jul 16, 2002 09:04 AM
