new assembled engine white smoke when hot
hello,
I have started the new assembled and run it in idling. But it issue a white smoke when the engine hot. but never see the situation when engine is cold.
Somebody told me that a normal with the new assemble engine because there a some oil in the exhaust system. but i am confusing is that a oil burning in the engine?
how do i know what the issue is that?
That why there are no white smoke when cold?
i am confusing is it the valve stem seal problem. because i remove the exhaust header, i see the exhaust port get wet but i dun what that is it, it does not like oil.
Re: new assembled engine white smoke when hot
O.G. triple O.G.
You should have checked the cylinder walls prior to the rebuild. On mine, I added water into the block to make sure no leaks. My block was a reman, bored to 75.5mm. I did this for reassurance.
Thanks,
otherwise, i want to ask if the crankcase pressure is high, that will cause the oil leakage from the oil pan gasket? because i have the same situation in same time.
but i really dun understand why just happen in hot engine.
I think i need to check any oil on the piston head or compression leak down firstly.
O.G. triple O.G.
if you're still using the "black box" on the back of the block, make sure the PCV valve isn't clogged. I didn't use one in mine. I added a 10AN fitting and ran it into a catch can.
Am i right,,,,HAHA
I'm assuming this is from exhaust..
White = water
Blue = oil (takes practice to tell)
Black = fuel
You haven't said how much run time it has total, but some water/moisture burn off from the exhaust is normal. Valve seals are more likely to show oil on first start up and wot.
Jumping to cracked sleeve is crazy.
White = water
Black = fuel
White = water
Black = fuel
White = water
Black = fuel
165 is not a problem, assuming you don't have high compression pistons. Even then the rings aren't seated yet.
You need to find someone that understands this stuff to help you in person.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
He means you haven't broken in the engine to seat the rings. First run rebuilds will burn oil and smoke until the rings are seated. To do this, the engine needs to be broken in.
I don't know if any one can give you concrete answers as often compression testers read differently. They are correct though. You need to drive the car. Start with light throttle pulls and work your way up to half throttle then 3/4 throttle. The rings need the cylinder pressure to press against the hone on the sleeves so they can wear in correctly. Do an oil change after about the first 40 min of run time. I wouldn't sweat it too much, my motor smokes pretty bad on initial start up and after some pulls it cleared out.
MugenGTR
05-24-2011 06:48 AM
classciv
04-21-2006 11:07 AM
TurboTeG4
08-10-2005 02:49 AM
