What seats fit a wagovan?
Old Sep 15, 2005 | 09:07 PM
Spence's Avatar
Default What seats fit a wagovan?
Hey guys i was going to put some ek seats in a wagovan but it looks like those dont fit so what fits i want to replace those nasty stockers also what rears work?
Old Sep 15, 2005 | 10:23 PM
Spence's Avatar
Default Re: What seats fit a wagovan? (Spence)
up
Old Sep 16, 2005 | 08:16 PM
Spence's Avatar
bump it up
Old Sep 17, 2005 | 05:43 AM
Spence's Avatar
up
Old Sep 17, 2005 | 06:04 AM
davens's Avatar
Its going to be a custom job because nothing bolts in. Or maybe it does, but I've never seen it...and I've looked.
I put 2001-02 Civic seats in mine...required lots of cutting and welding. You'll pretty much need to put the existing wagovan seat rails on whatever seat you want to use.
Some people will try and tell you that swapping seat pans is the be-all/end-all answer, but that only works on a couple of very specific seats.
For the back, whatever seat you use for the front...have an upholsterer redo the back in the same fabric. Back seats are easy/pretty cheap compared to the front.
Old Sep 17, 2005 | 07:12 AM
Spence's Avatar
Davens i was told that integra's will bolt up but only 3 bolts will go in im trying to find this out cause i found that ek seats dont work my wagons seats are shot so i need something
Old Sep 17, 2005 | 07:42 AM
949's Avatar
949
post pics of the install and mod for us who are planning on doing this too.
thanks
Old Sep 17, 2005 | 07:54 AM
davens's Avatar
I'd want more proof then "someone says" before I shell out the money and waste my time.
Maybe you can get 3 of the 4 of the bolts in, but there are a few other things to consider:
1. Seat height. They're not all the same. The wagon seat is pretty high. You may find yourself drving little old lady style...barely able to see over the steering wheel.
2. Seat position. Sometimes they won't line up with the steering wheel...like
both seats shifted toward the center of the car a couple inches. Still driveable but you'll be banging elbows with your passenger more often.
Or worse, they're actually crooked.
3. Level. Some seats will sit higher or lower on one side or front-to-back.
4. Range of adjustment. Can the seat rails and reclining position get you where you want to be? Some seats will leave you leaning waaayy back even though they are in the full upright position(this is related to #3).
5. Do they match? Not just the rear seats but the rest of the interior. Dash, door panels, carpet etc
Old Sep 17, 2005 | 06:04 PM
Spence's Avatar
bump someone has to know
thatcivic96
Oct 2, 2012 09:56 PM
Whatever
May 4, 2009 10:34 AM
ief9i
Jul 4, 2008 05:36 AM
davenport517
Mar 12, 2007 07:46 PM
infam0us
Aug 28, 2004 02:03 PM
