sleeved droped
Old Sep 15, 2005 | 05:49 PM
rattyrat's Avatar
Default sleeved droped
built b16 hhad sleeved block now block reports of sleeved droped 1/4 of inch what to do know?
Old Sep 15, 2005 | 10:06 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: sleeved droped (rattyrat)
maybe talk to the machine shop that installed the sleeves
Old Sep 16, 2005 | 08:54 AM
Darton Sleeves's Avatar
Take it back to the machine shop that installed the sleeves. Either the block was not machined properly or the sleeve was not seated completley before decking.
Old Sep 16, 2005 | 09:53 AM
Kendall's Avatar
And now for the million dollar question:
What brand sleeves?
Old Sep 16, 2005 | 10:07 AM
1700anddroping's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">And now for the million dollar question:
What brand sleeves?</TD></TR></TABLE>
i am waiting for this also.**** is gonna hit fan once again....has nothing to do w/the sleeves itself...just the installer......would be my guess.
harv
Old Sep 17, 2005 | 03:50 PM
rattyrat's Avatar
Default Re: (1700anddroping)
darton sleeves of course machine shop said they will redeck block and pistons but is that any good
Old Sep 18, 2005 | 04:47 AM
NJIN BUILDR's Avatar
Default Re: (rattyrat)
If it really dropped 1/4 inch than I wouldn't even think about doing it.If it was up to about .005" I would consider it.You should pull the sleeves and find out whats happening to allow the sleeve to drop.Just decking the block is a little risky and may not solve the problem.
Glenn
Old Sep 18, 2005 | 04:53 AM
non-VTEC's Avatar
it does not matter what brand the sleeves are. its the installation that's bad.
Old Sep 19, 2005 | 08:38 AM
Default Re: (non-VTEC)
With our design 99.9% of the time it is not the sleeve but the installation. If the sleeve dropped 1/4 of an inch you would have more problems than just a sunk sleeve.
Two things that most commonly happen to cause a sleeve sink:
Either the sleeve was not seated before the block was decked
or
The block's depth was not machined to the proper specifications
If they plan on re-decking the block they need to make sure and press the sleeves down to make sure they are seated completly.
The best thing to do is the remove the sleeve and check the machining depth unless they are sure the sleeves were just not seated completely.
The easiest way to make sure a sleeve is not going to sink is to measure the body depth where the sleeve seats and then machine the block so that the sleeve will stick up .002. Measure the block again to insure proper machining. Once you install the sleeves press them in until the sleeves are protruding .002. Let them sit with a plate holding the sleeves down until the loctite cures. Once the loctite cures and the sleeves are still protruding .002 proceed to deck the block.
Topdawgg
Oct 12, 2006 09:14 PM
score10
Jun 2, 2006 04:12 PM
dunkd
Aug 31, 2004 09:00 AM
GreddySi99
Oct 15, 2003 09:35 AM
