d16y8 head on a d15b7 block mini me what else is required?
i have the d15b7 engine in my car, and am about to buy a d16y8 head for a minime swap, then turbo. what else will i need to complete the minime swap aside from the head? thanks, i know this has been covered before, but i dont feel like fumbling thorugh dozens of search results.
You will need a Y8 or Z6 headgasket and a Y8 timing belt. Since your are planning on boost, you might want to consider getting a thicker headgasket as the Y8/B7 combo raises the C/R over 10 to 1.
ok. thanks. i know lower compression is better for turbo. but the point of the mini-me swap for me is to have a higher base hp for turbo. so if i did the mini me swap, using a thicker head gasket, would i really be gaining any power? if so whats a good head gasket to use? or do they just make different thicknesses of the same one? thanks
A Z6's combustion chamber is similar to a B16A heads cc, as is a Y8's cc to a GSR heads CC.
GSR/Y8 combustion chamber:
B16A/ITR/Z6 combustion chamber:
Darkane
Jun 18, 2005 05:42 PM
