complete obd1 to obd2 change
Old Sep 15, 2005 | 02:06 PM
92civichatch1's Avatar
Default complete obd1 to obd2 change
well maybe if enough people put there input and information we can use this as an easy link.
heres my scenario...
Ive got a 1992 civic hatchback CX which is obd1. I should hopefully be getting a 1998 Integra LS which is obd2 that was totalled, only thing is that the integra is an Automatic transmission. the trans i want is obviously a 5 speed. (keep this in mind)
Now can i take the body harness, engine harness, and ecu from the 98 integra to completely change my car to obd2? I know that i will have to pull the 2 resistors in the ecu and put in the jumper wire to make the auto ecu into a manual ecu. but will all this work? And what if any of the plugs wont just plug and play? and if i got the trans off a 1995 integra ls would the plugs on the trans plug and play.
Bottom line will all the plugs plug and play?
Thanks alot
Old Sep 15, 2005 | 02:23 PM
Default Re: complete obd1 to obd2 change (92civichatch1)
with all the swaps ppl do on this site somebodys gotta know the answer?
Old Sep 15, 2005 | 03:32 PM
hatchi's Avatar
you dont need to take the body harness as the Ls harness will plug n play in your cx.
Ls2DxMoon
33
Jul 16, 2014 04:01 PM
appelsos
11
Jul 11, 2011 06:24 PM
lilsicsoul
Engine Management and Tuning
Jul 7, 2010 05:04 PM
92civichatch1
Oct 28, 2005 09:15 AM
92civichatch1
Sep 15, 2005 02:59 PM
