question about ls tranny and lsvtec!
hi everyone,
I know I don't have an R but, you guys have better technical knowlege here so I like asking my questions here, I have a 2000 se, If i change the final drive in the tranny, will It work like a vtec tranny. I will be running a lsvtec with a 9500rpm redline! thanks in advance.......
The LS has the same ratios for 1st and 2nd as the GS-R (before final drive), so with a GS-R's 4.40 you would have the exact same gearing as a GS-R in first and second.
The problem is that the '94-01 GS-R and JDM ITR ring gear (final drive) is larger and will not bolt up to the LS tranny unless you change the differential too. The ring gear from a '92-'93 GS-R will work, and has the same 4.40 ratio as the later GS-R and USDM ITR.
Your best bet would be to instal a USDM ITR tranny. That would give you shorter gearing and an LSD for less than what it would cost to buy those parts and put them in your LS tranny.
1999all_motoR_teg
Aug 14, 2003 10:01 AM
