tranny question
Old Jul 3, 2006 | 03:03 PM
ED9man's Avatar
Default tranny question
I have a 92 USDM GS-R tranny. Is there an OEM ring gear and countershaft I can order to give it the 4.78 FD ratio? They may need to be replaced anyways because it was shimmed incorrectly by the tranny shop and has had a lot of freeplay and been pretty noisy for almost a year. If I can't do the 4.78 FD can I use the 94-01 4.4 ring and countershaft or just the 92-93 GS-R one? Thanks.
Old Jul 3, 2006 | 04:07 PM
mmuller's Avatar
Mad Scientist
Default Re: tranny question (ED9man)
the ys1 internals are just like all hydro b-series, meaning you can get the 4.78 final kit just like you would for a hydro tranny
Old Jul 4, 2006 | 05:31 AM
ED9man's Avatar
anyone else want to confirm this? If I did this I would need a JDM ITR FD and countershaft right?
Old Jul 5, 2006 | 08:22 PM
Andrew's Avatar
Default Re: (ED9man)
yeah, try checking the index that's stickied.
Old Jul 5, 2006 | 08:56 PM
SuzukaBlueAP2's Avatar
Default Re: (jdm_holla)
I don't know off-hand anyone that has done what you're asking, but I do know that the JDM Type-R 4.785 final drive gear set is a direct replacement for any 97-01 USDM Type-R and 94-01 GS-R transmissions. My guess would be that it would also work for the 92-93 GS-R as well.
If you have an LS transmission, then I believe the 5th gear is also required to make this work.
Old Jul 5, 2006 | 09:20 PM
Bense's Avatar
Default Re: (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know off-hand anyone that has done what you're asking, but I do know that the JDM Type-R 4.785 final drive gear set is a direct replacement for any 97-01 USDM Type-R and 94-01 GS-R transmissions. My guess would be that it would also work for the 92-93 GS-R as well.
If you have an LS transmission, then I believe the 5th gear is also required to make this work.</TD></TR></TABLE>
yes except the 5th gear is optional. but most people reccomend the ls 5th to reduce the cruising rpms. the jdm itr coutnershaft 1st gear or an infinitude 3.0777 1st gear is required
gsrob
Oct 10, 2007 12:48 AM
nc_mx_kid
Dec 26, 2004 04:20 PM
megotvtec
Apr 4, 2004 07:05 AM
sdchump
Oct 23, 2003 05:13 PM
integra2000
Feb 28, 2002 10:03 AM
