b18 88 civic problem...b18 has EGR?
Old Sep 15, 2005 | 07:09 AM
peiku's Avatar
Default b18 88 civic problem...b18 has EGR?
i just installed a 91 ls motor into my 88 civic dx. it was converted to mpfi before the swap. i thought that it would be a plug and play swap. now the ecu is throwing a code 12. i see the egr plug but there is no plug on my civic harness. am i supposed to wire the egr to the ecu? could the code 12 be causing my car to have no power below 2k rpm? it kinda feels like injectors are sputtering until i reach 2k rpm.
Old Sep 15, 2005 | 07:11 PM
peiku's Avatar
Default Re: b18 88 civic problem...b18 has EGR? (peiku)
bump
Old Sep 15, 2005 | 07:40 PM
B20Monster's Avatar
i think only the automatic integra motor has an egr. try to find a different integra ecu that is for a manual. .that should help some.
Old Sep 16, 2005 | 06:40 PM
peiku's Avatar
Default Re: b18 88 civic problem...b18 has EGR? (B20Monster)
could having an auto ecu be the problem with my low end sputtering? i have heard that using an auto ecu will feel weak. how do you know if the ecu is an auto or not? isnt it supposed to throw a code too?
Old Sep 16, 2005 | 06:57 PM
jspeczcturbo's Avatar
last 2 post are very true, either it's was a auto motor, or you have a auto ecu.
EJCivJdM93
Jan 26, 2005 03:48 PM
CRXracer88
Apr 16, 2004 11:59 AM
absolut b18
Aug 3, 2003 12:38 PM
5STAR3
Apr 24, 2003 03:40 PM
wronghand
Jun 6, 2002 04:53 PM
