Car is not accelerating?
Old Sep 14, 2005 | 04:07 PM
RboYi's Avatar
Default Car is not accelerating?
ok my car isnt accelerating like it should past 4500 rpms, it really pisses me off. I've already spent 500 bucks on repairs and didnt seem to find the problem. Clogged cat?? Please help me i'm trying to sell this thing! my car is shooting 200 psi on all cylinders.
Old Sep 14, 2005 | 04:08 PM
NuclearB18B's Avatar
Default Re: Car is not accelerating? (RboYi)
give us some more detail of what happens after 4500 rpm...
Old Sep 14, 2005 | 04:18 PM
acura_9485's Avatar
Default Re: Car is not accelerating? (NuclearB18B)
hey...my friend has the same problem, except its on a Nissan Spec v..go fig...but neways...he got it checked out..and the codes that were throwing was a gas sensor..something like that.......and a O2 sensor...so check those out..could be the same.. dunno..better than spending another 500 like u did...
Old Sep 14, 2005 | 04:51 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RboYi &raquo;</TD></TR><TR><TD CLASS="quote">ok my car isnt accelerating like it should past 4500 rpms, it really pisses me off. I've already spent 500 bucks on repairs and didnt seem to find the problem. Clogged cat?? Please help me i'm trying to sell this thing! my car is shooting 200 psi on all cylinders.</TD></TR></TABLE>
Sounds like a clogged cat, I could be wrong though.
Old Sep 14, 2005 | 06:11 PM
Sam92Teg's Avatar
Tell us what you have done already. How does it run before 4500 rpms? All you have to do to see if it is your cat is to drop your exhaust from the cat back and go for a spin. Don't go far or the Law might get ya. If it pulls hard to redline then you know your problem, if not, then hook that cat and exhaust back up and do some more searching. Does the cat rattle at all? Sometimes thats an indication that the ceramic has broken or dislodged inside, blocking exhaust flow.
After checking the cat, I would look at your all the plug wire connections. Maybe pull the plugs and look at their condition. There are just so many possibilities. It could be that you jumped time, so check and see if your crank and cam gears line up properly. Could be an ignition problem, coil, ignitor, plugs, wires, cap, rotor, and ignition timing itself. Could be a clogged fuel filter. Could be a bad O2 sensor. Good luck narrowing it down.
Old Sep 14, 2005 | 06:20 PM
PrinceAli132's Avatar
Tell us what you have done so far! Check the fuel filter, normaly you only notice those at a highner RPM, and also your catalytic converter.
Ali
Old Sep 14, 2005 | 06:24 PM
RboYi's Avatar
wow thanks guys for all the replies. actually my cat DOES rattle, its either that or my o2 sensor wire rattling against it. i just replactd the rotor cuz i figured that MIGHT be the problem but i guess not!
well it really just seems like VTEC isnt kicking it at all. it makes an INCREDIBLY LOUD noise at a little above 4k and at 6k it screams like its gonna die. pretty intimidated to take it up so high
where would i beable to find a new cat for cheap???
Old Sep 14, 2005 | 06:45 PM
Default Re: (RboYi)
i dont think its the cat
my cat was rattling and it was just the bottom heatshield ratlling. Alot of time its gets loose and you just need to tack it back, or a rock gets stuck in it and it rattles around.
Ali
Old Sep 14, 2005 | 06:54 PM
RboYi's Avatar
well considering that i could barely pass smog 2 years ago,.. it MIGHT be the cat if it really just decreases performance that much.
Old Sep 14, 2005 | 06:58 PM
RboYi's Avatar
wow i just figured that my exhaust went QUIET just about the time my car wouldnt accelerate, would the cat do that?
Old Sep 14, 2005 | 07:07 PM
JDMkidGSR's Avatar
Default Re: (RboYi)
Check your speed sensor, o2 sensor and your cat.
Old Sep 14, 2005 | 07:10 PM
RboYi's Avatar
well i just replaced the o2 sensor, i think it really is the cat. because at around the same time my car didnt work as well, my exhaust went completely silent, all it was intake noise. damn!!
Old Sep 14, 2005 | 07:19 PM
Default Re: (RboYi)
when i had a stock exhaust it didnt really make any noise. More like it wasnt audible at all
Old Sep 14, 2005 | 07:39 PM
RboYi's Avatar
no no sorry i meant i had an HKS Hiper exhaust and it went silent.
well my cat is out, right now im having the biggest big of a trouble trying to gut it but im pretty sure its the cat cuz its REALLY REALLY clogged up, like.. its ridiculously hard to drive a screw dirver in it iwth a mallot
lilcuban245
Jun 20, 2008 09:44 AM
ac_attak
Dec 20, 2006 10:04 AM
ntegraGS-R
Oct 6, 2005 04:20 AM
SjCiViCHB
10
Oct 29, 2003 03:43 PM
92 GSR
Jul 6, 2003 02:00 PM
